@ma1co @Vitaliy_Kiselev Thank you very much! I use your Hack successfully on 2 A6000 and a A7S, it's a great relieve for shooting Interviews with 4 Cams, but on my A7R unfortunately it doesn't work. Still 29:50 min. Any Idea? Protection on/off doesn't help.
Thank you, thank you, thank you !!! It works like a charm and I'm so happy that this blocking message bug now has been gone. I'm sure there are thousands that now feel a big relieve turning on their cameras without being forced to press an extra button.
Keep on the very good work.
@malco I've seen the new 'Enable & Disable PAL / NTSC selector #3 #4' at https://github.com/ma1co/OpenMemories-Tweak/commit/937ecb14607e35e554906da216a17143e113c5c9
Thanks very much vor taking care of that Sony bug.
@ma1co Yes! Thank you! That's really helpful for trying to learn how this stuff works.
Is there a relatively simple way to get telnet or adb running on a Sony camera? Also, is there a way to enable WiFi and keep it enabled without an app open?
I suppose I could try to write an app that includes a Java telnetd implementation, but I'd rather not learn to write Android apps just to get telnet running. I will try if I have to, but I thought I'd ask and see if there's an easier way.
I experienced the "Network Connection" error on 10.11 with multiple cameras. Couldn't get it working with the Sony site either. Perhaps the Photos app background process is intercepting the connection as the camera is connected to the computer.
I simply followed the instructions for doing it with the terminal command line and everything worked fine.
Apparently others on OSX 10.11 (El Capitan) are having issues. So it might be the os version issues.
Uncompressed RAW stills... not video. The new models have Uncompressed RAW for stills as an option.
Yes, camera was and is set to MTP mode.
Having problems connecting camera to Mac? Sony doesn't support OS 10.11 El Capitan. Useful article here: http://briansmith.com/how-to-update-sony-play-memories-camera-apps/
Someone over at DVinfo managed his RX100 mk4 to record 79 minutes without any overheating :-) http://www.dvinfo.net/forum/sony-alpha-mirrorless-dslr/531701-sony-30min-recording-restriction-hacked.html
@mattryandp Are you using the usb cable that came with the camera? Don't know if it will help, but firmware update fails when using standard usb cables.
So I have tried running multiple times via Safari since I'm on OSX and keep getting this error (Photo Attached).
What does Error: Network Connection imply?
I am definitely connected to wifi via my rMBP running this app. Trying to make this work on the A7R.
Also, anyway to unlock UNCOMPRESSED RAW in the older models prior to the A7II, A7RII, A7SII?
Works like a charm with my A7S. Thank you very much!
Works on RX 10 mk2 firmware 1.30! So great! Amazing work @ma1co - would really like to donate to this work if possible, it really helps in day to day work.
Next can be github, they are famous for instant bans.
Google suspended the site. I'm trying to find out why exactly. https://github.com/ma1co/Sony-PMCA-RE/issues/8
@ma1co What's going on? Did they shut you down?
Looks like they're shit scared of someone unlocking the raw video capabilities they're deliberately holding back to maximise their profits.
LOL
