Info:
PRICE IS INDEED SUB 10k in fact is SUB 8,6K with lenses
Available at:
Specs and related things
4K-ready
The first 4K-ready Super35mm camcorder in its class – providing an assured upgrade path to 4K acquisition and delivery - with full HD 1080p for today.The camcorder will also have the capability to produce 4K RAW 3G-SDI output via a future upgrade.
Super slow motion at 10x at full HD or 40x at lower resolutions
Incredible super slow motion capability of up to 10x slow motion at full HD resolution or up to 40x slow motion at a reduced resolution, giving you creative options that were once only available with specialist high-end equipment.
E-mount interchangeable lenses offer a wide choice of lenses
The E-mount interchangeable lens system utilises an extremely short flange back distance allowing you to use a huge array of lenses via a range of adaptors giving you almost unlimited creative options.
Built-in ND filters
The NEX-FS700E features built-in, ultra-thin ND filters, offering exceptional shallow depth-of-field on highlights. It also means less accessories to manage as no external ND filters are required.
3G-SDI interface and HDMI
A 3G-SDI output enables easy integration with highest quality recording formats.
Exceptional ergonomics
The NEX-FS700E has a refined ergonomic design with a robust detachable handle and grip.
Switchable 50 Hz and 60 Hz shooting
The NEX-FS700E is switchable between 50 Hz and 60Hz to allow 24p shooting in PAL areas and no PAL/NTSC limitations.
Selectable magnification and positioning of expanded focus
Expanded focus improvement allowing 4x and 8x magnification and a moveable area of expansion for easy focusing with shallow depth of field.
Camera profile settings storage on memory card
Up to 99 camera profile settings can be stored, allowing rapid adaptation to multiple shooting environments without time wasted adjusting parameters. Settings are also easily shared in multi-camera productions
The video right above this last review video was shot by me! The FS700R is amazing - 4K 60p and 4K 120P burst via SDI RAW. Same sensor as FS7. And the boxy form factor that is now becoming fashionable.
@Manu4Vendetta I only had a limited experience testing the FS700R in person, but we did do a candle light test. The A7s demos I've seen completely blow away the ISO performance I saw the FS700R display - so no, it is not at all in the same league. You can find some good example footage online and the ISO is fine (like many other cameras with sensors from the timing and pricepoint), but the A7s models are more like state-of-the-art and the difference is not subtle at all.
The price seems very tempting for the type of camera.
What is the maximum ISO usable? Not from the manufacturer, from users who have used it at night or in low light, is it close to sensibility of 6300/6500, A7S?
FS700R $3400 at Adorama.
it only output 4K via SDI only, HDMI is only 1080P out
well can anybody tell me what i can get as output with atomos assassin please ? some say there is 4k output via hdmi some say only sdi .. ? thank you
Slog2 vs REC 709 for Sony FS700
Another big price drop on the Sony FS700 down to US$4K (comes with a free metabones adapter too!): http://www.bhphotovideo.com/c/product/1010153-REG/sony_nex_fs700r_4k_nxcam_super_35mm.html (was $6k when it dropped in September last year, and just last June it dropped to $5k)
Hope that leads to a big drop on the second hand market! (Because I wouldn't mind buying one cheap next year....)
Still believe the PMW-F3 was a better buy for me personally :-) http://ironfilm.co.nz/dream-camera/
Newshooter just blogged about it too: http://www.newsshooter.com/2015/09/02/fancy-a-s35-sensor-camera-with-a-great-image-xlr-audio-sdi-and-hdmi-outputs-444-colour-pl-mount-and-built-in-nd-filters-for-under-4k-read-on/
Sony NEX-FS700 R at $4999 http://www.amazon.com/Sony-NEX-FS700-Sensor-Super35-Camcorder/dp/B00GOLD6YG/
Sony NEX-FS700 RH 4K Sensor High Speed RAW NXCAM Super35 Camcorder with 18-200mm Power Zoom Lens at $5599 http://www.amazon.com/Sony-NEX-FS700-RH-Camcorder-18-200mm/dp/B00GOLD7LS/
FS700 4K RAW
Sony FS700 price drop to $5999...
Fs700 Creative Test
