I was away for some weeks... and I started to think about the GH1.
If I can remember, it was the first cheap 24p shallow dof camera, and it started the revolution in digital cinema together with the 5D Mark II.
And it started all the hack revolution also... Tester13
GH1: how many people are using it these days?
Is the GH1 woth the effort to improve the Hack/Patch for it in the GH4/G7 4K world?
I suggest to check http://www.personal-view.com/talks/discussion/8601/panasonic-gh1-firmware-research-testing
As original GH1 patches have no space for improvement.
So, it is more new development and work with disassembler.
I usually work with my a7s, and sometimes with BMCC, however every time I pick the old GH1 (my first camera) I realize that it has the nicer color palette out of the box :) Ok, there are lots of camera today which have a more "modern look" and better quality indeed, however every time I watch GH1 footage not graded, just straight from camera, I have the impression that I am dealing with a particular film stock, "hot" color, nice reds, that has in my opinion a great analogic feel. Just in these days I have watched two films by the independent director Lanthimos: visually, the first one, "Kinetta" , shot on 35mm and only natural light, has a particular feel which reminded me of GH1 footage: pale colors, noise in shadows but very nice skin tones; the second, "Alps", shot on RED, has a look very close to the cinematography of Upstream Color (mainly GH2 and Voigtlander, clinical look, shallow depth, bluish tint). Old, glorious GH1, I will never sell it :)
following @humpman advice I developed two long gop attempts for gh1:
seti = 48Mbps
setj = 42Mbps
same gop setings in seti and setj = 24p = gop12, 25p = gop12, 50p = gop24, 60p = gop30
both using the reasonable values for the 1080p and 720p constants.
I do not have the GH1 so I cannot test...
I was thinking to get an used GH1 if I could find a cheap one...
But I do not want to keep pursuing perfection in hack patches anymore...
I just would like to increase the datarate a little bit, just to get a better image, and I would like to avoid pulldown in post production, so native 24p is welcome also. If there is a simple way just to increase datarate and get stable native 24p it would be enough... even a 32Mbps datarate would be already good.
Is there a simple way in PTool to do this, changing just few things?
If you ask me - you are wasting time.
I developed eight patches based on the idea of small datarate increase and native 24p, I used same rounded multiplier for each recording mode and video buffer. I used long gop. The idea is to make it stable and an enough image quality. In each patch there are lower 720p datarate in the other recording modes also. The Overall datarate is a little higher using same rounded multiplier, but it is lower than the buffer. For information read yellow box in PTool or open the txt file to read. After download rename txt to ini file extension. Developed using PTool 3.66d and Panasonic 1.32 latest firmware.
setA = 32Mbps, buffer 40
setB = 28Mbps, buffer 33.5
setC = 24Mbps, buffer 28
setD = 40Mbps, buffer 50
a little lower versions, using the buffer value to calculate the datarate rounded multiplier:
setG = 30Mbps, buffer 40
setH = 25Mbps, buffer 33.5
setI = 21Mbps, buffer 28
setJ = 38Mbps, buffer 50
(in the first setJ, where the yellow box comment show 29 please read 19, it is correct in the patch, just the yellow box comment is wrong, I uploaded it again with correct comments in yellow box as you can see below)
Where the patches start to repeat from A to J they have higher 720p H and L slots, H value moved to L and new H in between. This is an attempt to make the 720p more stable in H and L and also allow higher datarate in H and L slots.
I hope these can work properly, feedbacks welcome!
You are better stop with this. As I said, GH1 require completely different approach.
And bunch of not tested and not working setting won't help here.
@Vitaliy_Kiselev no problem. you can delete this topic and all the patches.
@apefos To tell the truth, the GH2 still has a terrific potential to be developed!
I found different ways for it. But the memory cards available for this camera are too slow.
You got me wrong.
I just said that to reach the goal you need to do different thing.
