Inside FCP, I get field dominance as Upper Field. However, when I try to deinterlace it using Compressor or other FCP plugins, I am still left with interlaced artifacts. So what is the workflow that people use to deinterlace this footage ?
@nomad I shot 50i on the GH2. Interlaced. For some reason, FCP displays better when its set to Field Dominance "None". If I leave the Field Dominance with default values - Upper field first. There are interlaced artifacts even after deinterlacing. Very strange. Let me fix up my comp so I can post grabs.
I will take a snapshot of the interfacts within FCP. Interesting - When the field dominance is changed to none, the artifacts go away. However, when I render with Compressor and upload to youtube, the file is rejected.
I faced the same problem, and tried various methods, including different codecs. If you are shooting in 1080i, I suggest to leave it as interlaced. FCP will detect the fields automatically, and optimise the playback. I found that rendering everything as interlaced yields the best results: I dun see artifacts, yet the final images, even in ProRes HQ, have an acceptable level of softness, unlike most interlaced video which is stark sharp.
Guys. I dont need an explanation of how deinterlacing is done. I am aware of the resolution issues. I am simply asking if anyone has manage to deinterlace GH2 footage in FCP. If so, what settings did you use in the field dominance ? Also, did you manage to remove all the interlace artifacts in the footage (to indicate that you deinterlaced properly) ?
You can not deinterlace it without degrading quality. 1) You can take one field from each frame and make it a frame - 1/2 loss in resolution 2) You can interpolate both fields - sharpness equal to 1/2 loss in resolution 3) "Clever" way of deinterlacing - only those areas which has motion - look for fcp plugins, this method produces the best results, but often needs retouching.
