Stabilize footage in post - options
  • I need to stabilize footage shot in post, and could not find a review of available options.
    Please post with your experience.
    iStabilize http://www.pixlock.com/index.php?Itemid=33&id=13&option=com_content&task=view
    Apple Motion Stabilizer
    CHV Plugins - Image Stabilizer http://www.chv-plugins.com/cms/Fx-Script/MotionTracker-collection/Image-Stabilizer.php
    Lock n Load Stabilizer - http://www.lockandloadx.com/
    BCC Optical Stabilizer - http://www.borisfx.com/units/optical_stabilizer.php
    VirtualDub Deshaker plugin
    Sony Vegas built-in stabilizer
    Prodad Mercalli Pro
    The best free option seems to be VirtualDub Deshaker.
    A comparison of Deshaker and the vesion of Mercalli with Vegas.
  • 61 Replies sorted by
  • I am very impressed with the CMOS Rolling Shutter/Jitter correction in Mercali V4 SAL. Below is a link to a YouTube example that shows a short clip shot using the Lumix 35-100 at 100mm with ExTele On. This is the worst case for jitter and jello for the 35-100. It is unusable footage as shot, but, when first processed with Mercali's CMOS correction, and then with Warp Stabilizer in PP, it is usable footage. Until now I had decided it was not possible to 'save' any hand-held Lumix 35-100 footage shot with ExTele on. It was always just too wobbly. Not anymore. Mercali V4's CMOS corrections are amazing.
    BTW: I did not use Mercali's stabilization, since I no longer see an option to "Fix Border" which would simply Crop. I don't ever want to 'zoom' in to fill the screen during stabilization, since you lose clarity and resolution. So, I use Warp Stabilizer and "crop only". Some people think the black bars are highly objectionable, but...I don't.
    I wish that Mercalli would add back in the option to "Fix Border" in their stabilization routines which they had in V2? This results in the same 'crop' balck bars as in PP Warp Stabilizer Crop Only. I also do notice a slight color shift in clips processed via Mercalli V4. I wish this were not there, but...it definitely is visible. Not sure why. It wasn't there in Mercalli V2. It would be nice if the color shift could be solved?
    As an aside: Of course the original footage is shaky. I was hunched down, hand-holding a lens with an equivalent FF focal length of 400 mm. Nothing to brace against. I admit I don't have the steadiest hands int he world, especially squatting down in the weeds, but...Mercalli V4 allows me to return to using ExTele mode on the Lumix 35-100. Hooray: it is possible to get some usable footage in that mode!
  • @Jspatz
    I just noticed that my stabilized footage has more contrast than the original. I am wondering if it is because my gh4 range is set 0-255. I am definitely losing delicate highlight detail. This is confirmed on scopes. I am using mercalli v4.
    My Gh4 0-255 Mercalli v4 stabilized files looks just the same as the originals. 0-255 levels both. The previous version converted 0-255 to 16-235.
    Is your editor doing some converting or clipping?
  • This is a simple and low cost stabilizer for gopros, I wonder if it works.
  • Because stand alone is more versatile for import / export since it plays the role of third party software and can adapt to any workflow. Plugin only works for 1 software at a time.
  • Why on earth did they make it a standalone program, and not a plugin as in the older versions?
  • I just noticed that my stabilized footage has more contrast than the original. I am wondering if it is because my gh4 range is set 0-255. I am definitely losing delicate highlight detail. This is confirmed on scopes. I am using mercalli v4.
  • @Vesku, the results on the examples from their site do look extremely compelling. A shame it seems to be only coded for Windows. Am I imagining things or wasn't there Mercalli on the Mac at one point? Maybe I ran it inside a VM, but I know I've played around with it before.
  • I use the free & open source vid.stabfilter from Georg Martius, I apply it using ffmpeg's "vidstabdetect" and "vidstabdtransform" video filters.
    See also this posting for example video links.
    The procedure I follow is:
    (1) Cut the relevant parts out of the camera recorded files in the compressed domain (not re-encoding, only cutting at I-frames). This is relevant (apart from saving a lot of time and storage) to not confuse the software stabilizer by irrelevant and possibly wildly moving scenery outside of the range I actually want to stabilize. I do this using mpv and the excerpt plugin.
    (2) I invoke a script that calls ffmpeg (which has been compiled with vid.stab support, you need to install libvidstab first and tell ffmpeg to use it when configuring before "make"). I've written two variants of this script, one for video with intentional motion in it, and another for video that should look as if the camera was mounted fixed on a tripod. The first script looks like this: ("\" at the end of the line is a line continuation for "bash"):
     ffmpeg -i input_name \
      -vf "vidstabdetect=result=name.trf:shakiness=5:accuracy=15:stepsize=6:mincontrast=0.3:tripod=0" \
      -c:v rawvideo -f rawvideo -y /dev/null
      -vf "vidstabtransform=input=name.trf:smoothing=10:optzoom=1:interpol=bicubic:tripod=0" \
      -c:v libx264 -profile:v high -preset:v faster -tune film -b:v 100000000 \
      -c:a copy -c:s copy -c:d copy -map 0 \
      output_name.mkv
    The second version of the script (for the "fixed tripod"-like scenes) looks similar:
      -vf "vidstabdetect=result=name.trf:shakiness=3:accuracy=15:stepsize=6:mincontrast=0.3:tripod=1" \
      -vf "vidstabtransform=input=name.trf:smoothing=10:optzoom=1:interpol=bicubic:tripod=1" \
      output_name.mkv
    (3) I import the resulting video file into my NLE (kdenlive in my case).
    (The choice of constant bitrate 100MBit/s for the encoding is meant to retain about the quality of the original 100MBit/s files recorded by my LX100, you could of course prefer other formats/parameters for your intermediate files.)
  • The new Mercalli v4 CMOS correction is very impressive. It corrects rolling shutter wobbling, jello and vibration better than anything earlier. I can cure my vibrating and wobbling Pana 14-140mm OIS jitter completely with very little cropping. It is though a slow process.
  • The best is still to use Mocha or Nuke. They need a lot of work but you gonna get as much as you can from stabilization. Mocha is probably more straightforward and less processor intensive than nuke which requires both the expertise and the hardware. They also both allow to save more image by reconstructing the "out of the frames" from different frames which comes quite handy especially knowing cropping is a major issue with stabilization. Again it's not magic, it's always better to have a very solid shot in first place, don't expect miracles.
  • Now I have tested the demo version of new Mercalli v4. It has good improvements. I can now stabilize many clips with assigning the same settings to all files. There is still not a possibility to save settings.
    The luminance shift GH3/4 0-255 to 16-235 is corrected (hurray). It is funny because when I asked them earlier about it (v3) they said that the issue not exists but they have now corrected it silently.
    Rendering is still about the same than earlier and the bitrate goes easily very high with complex scene.
    There are some new features like NR/sharpening and clip combining. There are also new stab features with very slow analysing but those are optional. I can not say much about stab IQ, I just started using it.
  • and fast!
  • DaVinci Resolve has a great stabiliser and it's free.
  • Blender has got a great tracking tool, which can also be used to compensate unwanted camera movements.
    Moreover, here is a nice add-on to Blender that allows a selective video stabilization, by means of a rudimentary highpass filter to a selected tracking marker:
    http://sonneo.blogspot.com/2014/08/better-video-stabilization-in-blender.html
    After the filter is applied, only the fast, jittering moves are represented by the marker so that you can use it to get much better stabilization results!
  • http://www.nchsoftware.com/videopad/ The free version works fine as a front end for, I think, de-shaker. Group select your clips, right-mouse over them and stabilize. You can also customize setting.
  • Is there a good way to stabilize multiple files in batch?
  • When I have to, I use the offerings within Boris FX. I have in no way mastered it.
    That said on occasions I have gotten the best result with multiple passes ... often a rotational fix with cropping turned off, followed by horizontal and vertical ... sometimes 1 pass for each.
    That is I stabilise 3 times, rather than allowing the software to do all three at once.
    It might be worth a try.
  • has anybody tested the latest version of Mercalli?
  • Someone knows the rolling shutter rate for GH2 HBR 1080 25p ? I need it on deshaker.
  • @Jspatz
    Panasonic's Mega-OIS is designed to smooth out your movements rather than correct gross displacements. Try panning the Leicasonic hand-held - without the OIS it will be difficult to maintain a level pan free of jitters.
  • @LPowell
    Based on you comments about the Leica 14-50 I went and tested and can't see much OIS effect nor can I see it on the 14-140. I remember it being very pronounced on other systems. When a loose tilt knob allowed the VG10 to tilt down suddenly, the image in the viewfinder did not catch up for about a second. I have the switch on and the lcd echoes that OIS mode 1 is active, but the video looks about the same with or without it. Can anyone suggest a test or think of what I might be doing wrong?
  • AE CS5.5 Warp Stabilizer. With the Adobe special for CS5.5 Master Collection at this time, I am leaning towards buying the entire suite for 800 bucks. With the FCPX fiasco, PP + AE seem a better bet than FCP.
  • Colour me stupid, but regardless of the OIS mechanism, wouldn't this increase the flange distance? So it could only work if the adapter already had space to work in (i.e. It's a non native lens that's being adapted and the added space was required anyway)
    Better to have the OIS in the body, no?
  • I was thinking maybe I could design this and become a multimillionaire....but then again I doubt it would work.
  • yes an OIS adapter would be perfect, kinda like a half OIS lens and then you add the rest yourself :)
