Someone knows the rolling shutter rate for GH2 HBR 1080 25p ? I need it on deshaker.
has anybody tested the latest version of Mercalli?
When I have to, I use the offerings within Boris FX. I have in no way mastered it.
That said on occasions I have gotten the best result with multiple passes ... often a rotational fix with cropping turned off, followed by horizontal and vertical ... sometimes 1 pass for each.
That is I stabilise 3 times, rather than allowing the software to do all three at once.
It might be worth a try.
Is there a good way to stabilize multiple files in batch?
http://www.nchsoftware.com/videopad/ The free version works fine as a front end for, I think, de-shaker. Group select your clips, right-mouse over them and stabilize. You can also customize setting.
Blender has got a great tracking tool, which can also be used to compensate unwanted camera movements.
Moreover, here is a nice add-on to Blender that allows a selective video stabilization, by means of a rudimentary highpass filter to a selected tracking marker:
http://sonneo.blogspot.com/2014/08/better-video-stabilization-in-blender.html
After the filter is applied, only the fast, jittering moves are represented by the marker so that you can use it to get much better stabilization results!
DaVinci Resolve has a great stabiliser and it's free.
and fast!
