Something tells me that you do not understand that silent shutter means :-) And how to use and not use it.
But some pictures still look weird.
this is why a7s is not a pr0 stills camera... i went out shooting in FF with silent shutter and cont. shooting mode. m42 lenses.
this is the garbage i got back. FFS! 0.o
Review at wolfcrow.com: http://wolfcrow.com/blog/the-sony-a7s-review/ Complete and well done as usual.
@last_SHIFT thanks for the info!
@filmingart are you talking about when the blue turns to purpleish color when you are over exposed?
We need a fix for the highlight problems in blue channel. Had footage ruined because of this........
Film Covert A7s Profile released:
http://www.filmconvert.com/download/Download_camera_packs.aspx
@osciallian Thanks! I have been learning grading a lot lately, but I'm not sure how I could improve. It still isn't very professional looking and I'm not sure how to reach next level. FE 35mm f2.8 is a great lens, but there seems to be some kind of software problem with A7s body and the lens. If autofocus doensn't nail the focus it starts to wiggle and saw around the focus point at very high speed and it continues even if the camera is set to manual focus. Strange. I have been in contact with Sony with no luck. Anyone else has the same problem?
@vstardust Lovely footage! Goes to show that you only need a 35mm :-) The grading looks great!
http://forum.atomos.com/showthread.php?53033-Sony-A7s-quot-breaks-quot-SLOG-2-on-it-s-HDMI-output!
Looks like there's a problem with slog over HDMI with this camera. Check out the link from the atomos forum - apologies if someone has posted this already..
We did some hiking in Lapland a couple of weeks ago and this is what we saw. Shot entirely with Sony A7s and small tripod/+monopod. 90% with FE 35mm f2.8 and few shots with Contax Zeiss 28mm. Edit in Premiere CC, colors in Davinci Resolve 10. Slog-2 with "Kholi's PicPro"-settings. Any ideas how I could improve?
Micro Four Thirds lenses will fully cover the a7S active sensor area for 1080p video when APS-C mode is used along with a 1.3x zoom setting.
But you can only adapt all-manual Micro Four Thirds lenses to E-mount. There is no Micro Four Thirds to E-mount adapter for electronic lenses.
Please, one question: in your opinion, would be possible to use micro 4/3 lens (with adapter) on this camera, in aps-c mode, without vignetting (precisely 25mm Leica and slr magic 12mm)?
Thank you a lot
What ND's are you guys using for SLOG2 I am interested in getting an A7S someday and want to know what the best ND's ARE and how many stops as well?
Without makeup, I would look like an old potato; with makeup, I look like a Yukon gold.
You are wrong... Better go read about crop factors and what cropping does to the angle of view. It's not a good flame topic to have here. In APS-C mode the effective sensor area is the same as any APS-C camera's. APS-C lenses do cover the a7S's APS-C crop mode.
Awesome :D Also forgot to ask: APS-C lenses ought to cover the APS-C mode of the A7s, though I wonder if the focal length remains without the crop factor, given that this is full frame camera. Meaning the 11-16mm Tokina would be a 11-16mm full frame equivalent when used in APS-C mode, since the mode only crops the vignetting. Or am I wrong?
Also Bt.709 gamma only goes down to ISO 200.
Hi @Adinan, you can access all ISO's in any picture profile, with the exception of SLOG2, which cannot go below 3200, but there are no high ISO restrictions on any PP.
Hey guys. I don't have this camera, but can see a use for it in ultra low light on a feature film. All that aside, I was curious to know if you could access all the ISOs ~200-409,600 in any colour profile, or if the 3200+ ISOs were limited to SLOG2, seeing as any tests I've seen only used SLOG2, and I personally don't like flat profiles at all. Thanks :)
it was my daily business for some time and you can believe me it's 90% photoshop. You can see the make up clearly at the eyelids but not at the cheeks. Bright white eyes = 100% photoshop. And they forgot to retouch the hands.. ha ha ha
