This Italian-made one looks pretty good: http://www.sturdyshots.com/sturdy2014/sturdyflight/
Maximum capacity is 1.5 kg, so no good for the BMCC etc but fine for the GH4, BMPCC (there's footage on Vimeo of it flying a BMPCC), 70D etc.
EDIT: in spite of the stated weight limit, there's a video of it flying the BMPC4K:
anybody seen the came5000 in real life?
http://www.came-tv.com/came5000-ready-to-run-3-axis-brushless-gimbal-stabilizer-p-363.html
I suggest to wait some time for Varavon or similar products of you can. As CAME is just reseller brand, they do not have engineers and such as I know.
With arm
Not sure where else to put this. DIY "3-axis gimbal" achieved by mounting an inexpensive 2 axis gimbal on top of a glide cam.
Probably wouldn't work well for heavier bodies, but seems pretty damn good for my GH3/4
Original source/Discussion:
Raw Footage:
"Behind the Scenes"
I just learned from Feiyu Tech that the new 3 axis gimbal is now available for order in China. It is very competitively priced at RMB 2199 (about £210) on Taobao.com. I will post a review as soon as I can get hold of a unit, probably in early July.
Does anyone have any experience of using a 3 axis gimbal (costing less than £500) with DSLRs? I'm looking for one to use with Canon 7D & 6D, and have been looking at the following
http://www.came-tv.com/came7000-3-axis-gimbal-dslr-video-stabilizer-p-471.html?ref=cheesycam.com
http://www.rctimer.com/product_1008.html
http://www.foxtechfpv.com/eagle-eye-hhg5d-dslr-bl-handled-gimbalwith-controller-p-1278.html
I'm concerned about the overall 'smoothness' of the stabilising, the weight & build quality of the rig, and the battery life. Any info would be great.
@LarryKetang, you can get more info from Chessycam website about the came7000. The guy at chessycam also says that came-tv is working on making profile for various popular cameras and lens combinations. If that turns out true, then it will be quite great and very affordable.
Does anybody know how this 3 axis gimbal performs with a GH2+pancake? http://www.hobbywow.com/en-steadymaker-fpv-3-axis-ildc-handle-gimbal-stabilized-w-motor-gimbal-controller-p236569.htm Thanks
Very fun, cheap small gimbals
Is it for gopro only? Or it'll work with small Panasonic cameras also?
Seems like copters gimbal on top of handle :-)
Yes, it is designed for GoPro cameras. For small Panasonic cameras to work this would require modifications of the bracket which currently holds the GoPro in its place. This bracket is screwed onto the tilt axis. So in theory at least it should be possible to carefully unscrew it and replace it with a DIY solution for a slightly bigger camera. Something to keep in mind when tempering with the current gimbal design is that the current firmware of the gimbal is for the small GoPro, so a slightly heavier camera may throw the gimbal off balance or overwork the gimbal motors.
I will record some stabilised footage during my upcoming trip to China and post it on YouTube.
Got my FeiyuTech 3 Axis handheld from china the other day, first go with old gopro black, just getting a feel for it, works well for what it is I think. I'll get it smoother next time I need to follow through the motion more and holding the handle parallel to the floor seems to work better rather than upright, snatched it a couple of times, but still that was all hand held on foot on a rough surface, I was impressed even if no one else is :)
Hello, I use a CAME 7500 and it works very well! I wrote an article on my first impression (in french sorry) here: http://www.5mars.com/came7500
GH4 + Voigtlander 25mm:
