Neway CK700-HOX, 1280x800 IPS monitor with vectorscope and waveform
  • 123 Replies sorted by
  • But I can't get this thing to work for longer than 3-4hrs at a time. I've used all kinds of BNC cables, all the same result.
    Can you provide more details? It only happens during continues use?
  • Still having trouble with the SDI version here. It's a fantastic monitor, and I love the image and all the features. But I can't get this thing to work for longer than 3-4hrs at a time. I've used all kinds of BNC cables, all the same result.
    I know the BMCC is not the issue, because soon as it loses a signal, I just connect my old monitor and it works fine.
    @Tscheckoff I tried that as well, but even if I take up to 10 / 15min breaks between uses, it'll go out eventually. I'm really stumped on this one.
  • Oh no, I'm talking about the plates that I got with my CK700. They're both for the Canons. Even says so on the plate.
  • Check photo above for plates.
  • Actually, they're both for Canon LP-E6 batteries.
    By the way, to anyone looking to buy, I can confirm that the CK700-HOX (HDMI only) does have aspect ratio guide markers (4:3, 14:9, 13:9, 15:9, 1.85:1 and 2.35:1) and that it remembers to stay locked in 16:9 display ratio rather than resetting to full screen.
    When I zoom in, however, the ratio seems to change and it will either stretch a bit vertically or horizontally, depending on your zoom level.
    Overall, I'm pretty darn happy with it. Will know more tomorrow when I take it to the field for a shoot job.
  • They are for different batteries :-)
  • I just got mine and so far, I'm loving it! I just have one question: Why do we get two battery plates? Is there a way to run two batteries on there or something?
  • Alright, so I bought this when it was on sale for the Weekend deal (Thanks @vitaly_Kiselev) and I hope it'll be a really good monitor for its price range. @CFreak, how accurate are teh colors and contrast?
    Is it pretty usable in broad daylight?
  • I bought this from the Deals section on Nov. 4th and it arrived in the USA today, Nov. 11th. I only quickly looked it over, but, since it's on sale again today I thought I'd post my 1st impressions. The image is high quality, much better than my old monitor: http://www.personal-view.com/talks/discussion/2823/5.6-1280x800-on-camera-monitor-with-peaking-aka-h056/p1
    The waveform looks accurate and the peaking looks good (can be in color or monochromatic in peaking mode), the colors are adjustable, the pixel to pixel feature is in a menu and there is no hot key option for it. It came in a small hardshell case, which is better than none, but, not top quality like a pelican case. There are 3 1/4"-20 mounting holes (none on top) but the image can be flipped in a menu. I hung my old monitor from a top mounting hole, I wish this had one, but, the precision focusing this can give is what made me take the leap. Pictures:
    2592 x 1936 - 604K
    2592 x 1936 - 657K
    2592 x 1936 - 647K
    2592 x 1936 - 862K
  • @RomanLegion: Maybe it´s an overheating problem of the SDI input driver / circuit. Try to turn it off more often inbetween your shots (if that´s possible). That way you can at least expand the time - OR you´re not running into that problem at all.
  • So, Ive been using the CK700SDIX SDI ver for a little over a week now. For some reason with my BMCC, the monitor will only receive a signal for about 3 hours of use, and then say "no signal" after that. If I leave it alone for a day, it will again work for about 3 hours and give the same message. Not sure what's going on, but my old ikan SDI monitor still works properly with the BMCC, without issue, so I don't think it's the camera not sending out a signal.
    Anyone else come across something like this? Any settings you guys are aware of that might be causing this?
  • Just bought the CK700-HK for use with my BMPCC. Using HDMI input. For some reason I can only select between 480p/1080i for my input signal.
    Focus peaking doesn't seem to work at all but I could try my GH2 on it, but otherwise I like the monitor, great quality.
    What is the best way to get an image on it closest to what my BMPCC is seeing? What exactly is CAMERA ON/OFF? CAMERA off seems to give me a closer to view to my camera. What's PIXEL TO PIXEL do? It seems to zoom in. Is it for focusing?
    I've got it in 16x9 right now with UNDERSCAN on. Seems to be the exact frame as my BMPCC without any stretching.
  • It turns out the SDI version does have aspect ratio guide markers which include the following...
    In hindsight I probably should have bought the SDI first instead of the HDMI version as the markers are better than sticking tape all over the screen!
    Pundit seemed to imply it, I was just clarifying that all versions have them for anyone looking at this monitor.
  • So it isn't just the SDI model that's been updated to have the extra guides.
    I think no one said that it is SDI only.
  • Thought I'd share some of the information I've gathered about this monitor.
    Guides: "All the monitors of CK700 Series support 16:9. 4:3, 14:9, 13:9, 15:9, 1.85:1, 2.35:1 aspect ratio. Of course CK700HOX does."
    Second, here's a chart that shows all the supported resolutions + framerates. "O" means it works, "X" means it doesn't work. I honestly don't know what the "/" means (probably "it depends"). Anyway, I hope this helps Blackmagic and GH4 users (and anyone else).
    I've ordered one, so I'll report back when it arrives!
    489 x 972 - 78K
  • Okay my bad!
    They sent me a picture of the menu system showing the volume at the bottom of a drop down menu. There are three additional functions which can be assigned to the rotary knobs.
    These include, sharpness, volume and backlight. They are not assigned by default and therefore cannot be adjusted until they are assigned.
    It is mentioned in the printed manual but the print is microscopic and my eyes are not what they used to be! Menu picture made it much simpler to locate other hidden options.
    Volume is good now out of both headphone socket or speaker.
    The headphone socket buzz is still present but it is fixed in level and doesn't change as the volume is adjusted. Kind of sounds like and earthing/shielding problem.
    Also backed off the sharpness to zero as it was causing ghosting even when turned up slightly.
  • @Vitaliy_Kiselev
    There is a data port on the rear of the monitor under the battery plate. So it can be updated.
    Now I'm starting to get more work with a small production company SDI is the only option.
  • @Vitaliy_Kiselev
    When used as a directors split I would like to be able to feed audio via the monitor rather than have to use a separate dedicated feed with a mixer or wireless audio.
    This is especially important when on location outdoors as in the attached example photo.
    This was on location two weeks ago shooting a music video. I was gaffer.
    LED lights were powered from V-Locks.
    Director with split is on the far right.
    There was no location sound being recorded in this instance but you get the picture!
    No GH_ used here. Camera was a RED Epic with Lomo Anamorphics.
    2048 x 1362 - 495K
  • Excuse me, im very interested in this monitor but i dont found any reports with this and the GH4 compatibility or modes, especially 24 Hz.
    I did not saw any problem reports. Usually companies have cameras for tests. And most reports of some monitors having issues usually date back to GH4 into time and mostly concerns cheap monitors.
  • @pundit
    I also have the CK700 HOX (HDMI version) and have noticed the randomly flickering audio meters and waveform/vectorscope displays.
    Please check topic before posting, it is fixed long time ago on all monitors. Was only on first batch.
    DIY firmware fix or I ain't gonna be a happy camper!
    If you look above in the topic you'll see that it is not user firmware upgradable.
  • Just received my CK700-SDIX (SDI version).
    It also has Screen markers, marker color, marker mat and marker line thickness.
    No anamorphic de-squeeze or rule-of-thirds grid however.
    Rule-of-thirds grid should be doable in firmware.
    Overall it seems fairly good except for a continuous cyclic distortion (random changing oscillation) emanating from the headphone output which changes when the video input is altered either by adjusting the menu or stopping or starting the video input.
    Main loudspeaker output is clean.
    I also have the CK700 HOX (HDMI version) and have noticed the randomly flickering audio meters and waveform/vectorscope displays. This monitor also suffers from low volume but doesn't have the distorted headphone output of the SDI montior I received.
    I hope this and the flashing displays are a DIY firmware fix or I ain't gonna be a happy camper!
  • @Aksel
    Check previous page.
  • anyone has a problem with focus peaking? because I simply don't have it at all
  • Still has no way to do an anamorphic desqueeze of some sort, no
    Not yet. Engineers have this wishes.
