Specs:
The Canon PowerShot G1 X Mark II raises performance and quality to new heights in a compact, brilliant design. Featuring a huge, 1.5-inch 12.8 Megapixel High-Sensitivity CMOS sensor, a powerful DIGIC 6 Image Processor and an all-new 5x wide-angle optical zoom lens with Optical Image Stabilizer and a circular, 9-blade aperture for stunning blurred backgrounds, the PowerShot G1 X Mark II delivers the outstanding image quality you would expect with a digital SLR camera but in a portable, Wi-Fi and NFC enabled package.
Canon 1.5-inch, 12.8 Megapixel High-Sensitivity CMOS Sensor
Almost as large as the APS-C CMOS sensor found in many EOS digital SLRs, and bigger than those found in 4/3 system cameras, the PowerShot G1 X Mark II's sensor sets the standard for sensitivity and resolving power in compact cameras. Each cell area is 4.5x the size of those found in 1/1.7 type sensors and is thus able to capture more light at the pixel level. This means better detail, even at higher ISOs, with minimal noise and distortion and, thanks to the sensor's wide cell pitch, breathtaking dynamic range. The PowerShot G1 X Mark II camera natively captures images in the 3:2 aspect ratio, which is the same as Canon EOS SLR cameras. The PowerShot G1 X Mark II also features a new Aspect Ratio function, enabling RAW image capturein both 3:2 and 4:3 aspect ratios while maintaining the same angle of view.
Previews:
Available at:
PowerShot G1 X Mark II Refurbished for $479
https://shop.usa.canon.com/shop/en/catalog/powershot-g1-x-mark-ii-refurbished
For those seeking a small fixed lens camera to serve as a backup and/or a secondary camera to a DSLR, the G1 X Mark II can provide the image quality you're used to with an entry-level interchangeable lens model.
Mark II will suit photographers who want a walk-around camera when they don't want to lug a lot of equipment about. It's also an option for minimalistic travelers. Both G1X models provide a similar suite of functions to a DSLR in a relatively compact body, along with support for Canon's CR2.RAW file format.
The G1X II is obviously a camera aimed at skilled shooters, both in price and variety of settings. But that does mean that some of the more fun features that we see in other cameras (and other Canon modes) don't seem to have made the transition to this slightly more dour camera. There's no panorama mode, and the G16's 120fps video isn't there (I assume because of the much larger sensor). All told, the G1X II is a brute that needs to be babied.
http://www.imaging-resource.com/PRODS/canon-g1x-ii/canon-g1x-ii-shooters-report.htm
As far as high ISO performance goes, the Canon G1X Mk II seems to be about on par with Micro Four Thirds cameras. In essence, that means that it is pretty damned good.
http://www.thephoblographer.com/2014/06/16/review-canon-g1x-mk-ii/
Canon Powershot G1 X Mark II has brighter lens with an improved zoom range, from 24mm to 120mm. Built in Wi-Fi and a 3inch touch screen let you quickly transfer images, as well as remotely control the camera. However, the camera is noticeably large, making it roughly the same size as a mirrorless camera, with a similar price point as well. For those that are familiar with Canon cameras, this should make an excellent backup to a DSLR however the relatively short battery life and slow continuous shooting when shooting Raw images is a little disappointing
http://www.ephotozine.com/article/canon-powershot-g1-x-mark-ii-review-25533
Area in which the G1 X II really shines is image quality. Its 1.5"-type CMOS sensor allows for photos that come very close to what you can get from a consumer or midrange interchangeable lens camera, even at high sensitivities. Its fast F2.0-3.9 lens lets the photographer keep the sensitivity low and also allows for very shallow depth-of-field (not to mention beautiful bokeh) - something normally reserved for interchangeable lens cameras.
http://www.dpreview.com/reviews/canon-powershot-g1-x-mark-ii/
The G1 X Mark II's image quality is excellent for a compact camera thanks to the large sensor that lies at its heart, although we did notice more noise appearing slightly earlier in the ISO range than on the original model.
http://www.photographyblog.com/reviews/canon_powershot_g1_x_mk_ii_review/
I would be interested in the cam if it had 24p. Surprised it doesn't.
Depending on how soon the lens get to f3.9 the increased low light performance from a larger sensor will be offset by the constant f2.8 lens of the RX10.
Canon Powershot G1 X Mark II will start shipping at May 9th.
