Driftwood Cluster X series 3:│moon T7│ЅріzZ T6│Nebula T7│Drewnet T9│
  • 1811 Replies sorted by
  • Is is a mix between the old apocalypse and the moon with all intra.
    granted with AFX - enjoy it.
    https://vimeo.com/athenemedia/queenofthewind
  • this is a trailer of my commercial making with gh2 with moon t7 ( and couple of hours later my gh2 died after not original battery suddenly turn off during the update for intravenus II :( Looking for new gh2.
    hope you enjoy!
  • All Shot On MoonT7
    A Video Of My Wife And Daughters Doing Their "Makeovers" LOL Sorry about the background had to stand the camera up on some books lol
  • @vstardust Looks great man.
  • @rsquires thx, grading is like painting
  • mostly moon t7 with a bit of t5:
    And here are some frames of my next project raw and edited (first frame is T5, second is T7)
    2048 x 858 - 757K
    2048 x 858 - 716K
    2048 x 858 - 866K
    2048 x 858 - 955K
  • @Celullo Beautiful shots and grade. Really great
  • Some skateboarding shot with Gh2 Nebula T7 720p 59,94fps.~f2 and Metabones Speedbooster + Contax Zeiss 85mm + 50mm f1.4. First scene with 1/2000, second one with ~1/200. Graded with Resolve 10, slow-mo with Timewarp. 2%.
    Do you have experience of motion and artifacting with Nebula? Would Slipstream work better?
  • Long time since I'm reading this forum and this my first real post. Shooted this film with GH2 + pany 14-140mm + Drewnet T9 (720p only) + Resolve (Cuts & Grade). Million thanks to Lord Vitaly & Sir Driftwood for make this possible !
  • A wedding shot with Moon T7..
  • Seems that the T5 is fashionable, this little clip is part of a short film I'm recording was made with the T5
  • @LongJohnSilver Fab footage! I love the 7-14 too. This looks amazing.
  • If it's serious you're slating at the beginning anyhow, or providing ample lead in. Go on start isn't really a safe production habit with or without slate, however, or in the case of tail slating. You should take a moment to confirm that footage is actually rolling, whether or not you need to confirm this to another party by announcing "speed!".
  • @TATZU Do you not find the sound is also missing for the first few frames? I've seen the sound problem reported on several forums for both GH2 & GH3. I follow driftwood's approach and allow a throwaway lead in.
  • @TATZU The first frame establishes rate control boundaries and the codec settings, in simple terms (and in moon) we are instructing the codec to try and reach +-4 QP of the initial setting rather than starting at a higher desired quantisation level - GH2 default = 20 (other settings have been 16) and although the first frame improves when set at a 'comfortable' level - the quantisation scalers come into their own to deal with low/high frequencies performance issues (e.g. artifacting, mosquito noise etc).
    In settings such as those found in moon we are instructing the high Quant / lowest Quant boundaries using a form of quantisation rate control and not so much relying on the scalers. Thus after a few frames picture quality drastically improves and maintains an even spread of 'lowest QP' figures throughout according to the picture being filmed (low is better/high is poorer). This will mean the first frame will look pretty shitty unfortunately - so give a second or two of lead in when filming to 'settle' then edit it out on the NLE.
  • @TATZU, didnt notice that before, does it look similar in quality loss as the clip preview image in-camera ?
  • Hey guys i've noticed several times that at the beginning of all my clips when i view them in premiere or anywhere else the first frame is always severely starved of quality and looks lower than vga resolution... Anyone else getting this on the files straight off the camera?
  • @LongJohnSilver Thanks for tip - will pass along to my scuba friend. Keep rockin - footage quite impressive!
  • @matt_gh2 actually the only viable solution is to stay hyperfocal focusing prior of the shot:
    http://www.personal-view.com/talks/discussion/comment/113965#Comment_113965
  • @LongJohnSilver Cool - thanks. A friend is looking to get back into scuba diving and she shoots with a GH2, so I'll let her know about this lens. I guess you use all autofocus?
  • @matt_gh2 7-14mm is a killer lens underwater
  • @LongJohnSilver Amazing footage! Insanely clear and detailed. Very cool.
  • First try of mmon T7 underwater. Non problem at all.
    Out there, a few hundreds of meters apart from mooring buoys, nearby walls, reefs and wrecks there is a unknown world waiting to be (re) discovered.
  • While shooting a wedding this weekend, the GH2 bumped itself from 720 to 1080 when I turned it off and back on. My shutter was still extremely high, but here is the result of what happened next! :)
  • Thank you very much for all of the input from everyone! :-)
    After comparing some footage I took with T5 to T7, I concluded that I liked T7 better, so I used that to shoot a project from noon sunday to late afternoon yesterday for some friends of mine.
    Shot it all in 24H with a Panny 12-35 and 45-175, onto Sandisk 32 and 8 gig Extreme Pro cards, and a 7" Lilliput 668GL monitor. Interior shots were lit with 6500K CFLs in softboxes, and exterior shots were mostly action (some hand held and some on a Glidecam HD2000), so not lit.
    Overall, I just couldn't be any happier! I'm a total amateur, but the footage I got with this setup exceeded my expectations, and to be honest, it actually exceeded what I hoped I could get. :-) Everything was sharp as could be, and looked truly HD. That 45-175 lens is phenomenal for sharpness and clarity.
    I had my personal computer on site, and I used PP CS6 to cut the project together onto a 720 sequence for the sake of cropping and whatnot. Other than one outdoor shot where the subject was backlit and there was some significant noise on his black nylon training vest, all of the editing went really smoothly. In that one case where there was a lot of noise, NeatVideo did the trick really nicely, but I was happy I had some computer power there.
    There were a couple of other little spots where I noticed some minor noise in dark areas, but it never seemed to even register with my friend, who has a good eye for photos and video, so I just left it alone (maybe he noticed it, but it was minor, so he wouldn't have wanted to mess with it in this case anyway). We were under a strict deadline to get the project submitted for a network TV casting call, so the less I had to do to the edit, the better.
    By the way, my camera is still in the van so I'm going by memory here, but I shot it in Vibrant mode with noise control at -2, sharpness at 0 I think, and I think I had a positive number for saturation, and either 0 or +1 for contrast. I was really hoping for something that looked good straight out of the camera due to the time constraints, and it DID!
    So I do plan to try out Moon T4 just for the fun of it now since @matt_gh2 provided me a link for it, but I have to say I will be surprised if I end up sticking with it. Moon T7 is just amazing, and one of the ways it really shines is when I upload test shots to YouTube to check the damage of their compression. For some reason it seems like T7 24H footage shows less (or a lot less) impact from the YouTube compression, and looks PHENOMENAL.
    Thank you again to everyone! :-)
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
