Neway CK700-HOX, 1280x800 IPS monitor with vectorscope and waveform
  • 123 Replies sorted by
  • @vicharris I haven't checked it in detail and I don't have a comparision either but I didn't see any issues up to now.
  • @peaceonearth Good to hear. Question. How responsive are the turn knobs? This has some of the same parts as a other monitor I had and it seems if you turned the knobs a little too fast, they wouldn't register in the menu. Does that make sense?
  • I ordered the SDI version on 8 Jan and it arrived today. That was fast! It's a great piece of gear and on a first test it works perfect with the BMPCC. Audiometers. Yeah! Thanks for this great deal!
  • @Vitaliy_Kiselev, do you know if this model has a 'de-squeeze' live view mode for 2x anamorphic lens monitoring?
    It may not have a preset mode for 2x anamorphic de-squeeze, however, via the settings, can the vertical pixel height be reduced by, say, 50% to achieve the intended goal for 2x anamorphic monitoring? Thank you, VK.
  • Understood, thank you for the quick response!
  • Will this take the 1080p signal from the BMPCC without issue?
    By idea it must, but as it is new thing I did not see user reports.
  • Thanks for the quick feedback
  • 600nits are good, but if you are not on steadicam and use supplied hood you are ok with 400 usually.
    600nits panel are not very common and such brightness has its downsides (like light leakage in darkness for CT76, it is much rarer with new batches but still happens sometimes).
  • So this monitor doesn't have as bright of a screen as the other one correct? 400 vs 600. How big of a difference will this make on a bright day outside?
  • What type of aspect ratios guides are there?
    As far as I know it has set of standard rates. Without fine tuning ala CT76.
  • Damnit, my $699 SDI version of the older monitor arrived today xD I won't sulk though. I... won't.....! xD
  • @vicharris
    I added 3G SDI version price, difference is almost as you asked :-) It is also available.
  • Dang I bought one already. Looks good.
  • Wow what a great software feature pack.
  • I'd pay $200 more for sdi to not have a converter box sitting on my rig and also worry about delay.
  • Wow, i wish i'd waited for this one but bought its baby brother. Vectorscopes would be amazing!
  • Damn, I just bought their SDI monitor from here last week xD Time to nag about firmware update?
  • @vicharris
    SDI is not cheap in monitors, but very heap as separate SDI-HDMI converter :-) Check the topics.
    As for SDI, I think it'll be soon for this model.
  • If they add SDI, I'm in.
  • this looks amazing... does it use the same ips panel as its predecessor?
    It is 1280x800 IPS panel, not the same. Just similar.
