GH3 Best Video Settings
  • 814 Replies sorted by
  • @Vesku that's kind of yours, thanks =)
    What "bothers" me in the christmas tree video, is not so much the visible increase of noise in middle shadows but injection of grey matter that result in the halos around ceiling lamp. I can understand this HDR being effective in some situations, but for me, shooting mostly with available light, this halos would render footage non usable 'cause extra post fixing time. All good
  • @lumixmaxgh3 I agree.. GH3 overall looks kind of orangey, pinky, pastel to me. I used to find the GH2 rarely was very 'off' due to white balance, i've regularly forgot to white balance on a GH2 and it was always fixable. With a GH3 if you don't white balance the orangey pinky pale tones take over. I love the camera apart from this but would love to know whats going on so i could fix it..
  • hi!i i'm new. Could someone kindly tell me a way to settings a color looks like canon? The main problem i find with the GH3 is that reds come out a bit ORANGE and yellows also come out a bit ORANGE. It kind of merges them towards each other and i can do nothing to restore it in post! yet i can find nothing on the internet about it Thank you
  • maddog, a bit offtopic, but the GH2 shot looks so much better, wow. I know it's a different lens, framing etc. but man... o_0 almost like RED vs. HV20 ;)
  • @starios
    These are sraight from camera and put together in Sony Movie Studio. No cc added.
  • it is really helpful for a fast shot if it is in camera, I insist that in post with flat shooting give better result to what we try (especially considering the exposure restriction in this mode) but helps alot
  • @Vesku is this with the in-camera preset or in post?
  • @maddog15 thanks :) Sorry I am off topic with those samples but those are quick tests that show to me that in a right shooting way with a nice frame a tripod or dolly, gh3 can handle some difficult styles with realistic image result if you don't lead it to extreme kitsch like mine - I am experimenting, yet
  • @maddog15
    OK. I made an vimeo account and loaded that last example of HDRvideo. Like I thought there is much left of original quality. Details and levels are gone but the difference is there. Sorry for shake. I Shooted with 20mm 1.7 + wide converter handheld so no stab.
    If you want to pixel peep see the captures I sent before.
  • @maddog15 I use the DSC OneShot chart. The back of the chart is half white and half-gray. It makes it a little difficult to set the white balance on the gray since it's a bit small. Then I make sure to shoot the front side of the chart. On the front side, it has 90% White, 50% Gray and true 0% Black, as well as the primary and secondary 709 colors (set at 50%, since paper can't be saturated that much). In addition, the chart has 4 skin tone shades. It's a great chart (and not cheap).
    Lately, I've been trying to keep the f-stop similar between lenses, but it's not necessary. I also found the Voigtlander 25 paired with the Panny 35-100 is a nice mix.
    On this shoot, the GH2 was in MCU and the GH3 was Medium. Next time, however, I think I'd switch it up. Reason is that the GH2 is much sharper than the GH3. This is more pronounced when the GH2 is in closeup, since you can make out skin pores, etc...
    I shoot with an Ikan D5W which has built in scopes. That way, I can set the whites to 90% on set. I'll try to get the f-stop I want and then futz with ISO. Worst case, I'll throw a vari-ND on either camera to get them close.
    In FCP X, I compare the charts from both cameras with the RGB Parade turned on. I'll crop in on the gray chip on the chart. Then I add the wvl_RGBbalance effect. I found it on FCP.co. Now, it's just a matter of deciding which image you want to balance to and set the R, G, and B values (luma, mids, and blacks).
    Next up, if necessary, I set the whites, mids, and black levels based on the chart. And then on to the colors. Ah, the lovely colors.
    Generally, everything BUT the skin tones are similar enough. The GH2 and 3 record skin tones completely different, as I'm sure you know. Also, magentas are pretty different. So, I'll do a selective CC on just the skin tones. Using the vectorscope, I'll just try to get the skin tones close.
    It's a multistep process and it doesn't always work this way. Sometimes, if I'm lazy (which has happened on occasion) I'll use FCP's Match Color function. On occasion it works great.
    Here's another example with before and after shots from another interview where I used the workflow mentioned above. BTW - In this scenario, I shot with the GH2 in ETC mode with the Panny 12-35mm - BAD IDEA. Lots of freakish noise. Whoops, I forgot about that. That's why I decided to shoot with the 35-100 on it.
    2072 x 1756 - 2M
    2072 x 1756 - 2M
    2070 x 1756 - 2M
    2072 x 1756 - 2M
    2070 x 1756 - 2M
    2072 x 1756 - 2M
  • @5thwall Hey exactly what kind or brand of Grey card are you using to set your WB? I'm extremely impressed with: 1. Color with skin tones you've achieved. 2. The matching up of GH2 and GH3 footage. The documentary I'm doing is a 2 camera shoot with my GH2 (Running MOON T5 as the close up) and my GH3 (the Three Quarter medium shot). Four interviews filmed so far. Some aren't too bad to color correct so they look like they were shot with the same camera. SOME of the interviews are a nightmare to match up! Thanks again for the great info. PS the shots below are straight out of the cameras.
    1919 x 1080 - 2M
    1440 x 809 - 1M
  • @Vesku I think people would love to SEE your videos. Not just pictures of your videos. We all understand that YouTube and Vimeo compress videos further. But since this is a "Best Video Settings" forum - that's what we do. We post our test or projects. As a video. (YouTube is Free.) Regardless of the online compression a 1080p video on YouTube isn't bad. In fact than would show MUCH more information that the pics you're posting. Can't wait to see. :)
  • Do you have GH3 - if yes then test it yourself. I dont have vimeo account and it kills quality anyway. These are actual stills from video. Matter is about dynamic range.
  • @Vesku would it be too much to ask to see the videos, a 3 / 4 secs of each?
  • @elkanah77 extremely impressive
  • It is cropped frame to save Vitaliys space. Height is 1080.
  • @Vesku how did you managed to record 4 by 3?
  • New examples of Creative control/High dynamic video in GH3
    1440 x 1080 - 229K
    1440 x 1080 - 218K
  • Thanks kupchenpo. Unfortunately, it won't arrive in time so I was looking for a local LA rental house. 5thwall - sent a PM so please call, if available.
  • @SuperSet I always rent my extra cams from Borrowlens.com. They are very reasonable for a weekend shoot.
    http://www.borrowlenses.com/product/Panasonic_Lumix_DMCGH3_Mirrorless_Digital_Camera
  • @SuperSet I could potentially rent you mine. PM me.
  • Kinda off topicO Anyone seen a Gh3 rental place in Los Angeles?One of my cams just went down and I have a weekend shoot.
  • @elkanah77 Looks great. Very nice.
  • My take on using both GH2 and GH3 together. Earlier posted in showcase section. Read description for details on grading. This is anamorphic btw.
