update: added mlv_snd which adds audio recording to mlv_rec
http://www.magiclantern.fm/forum/index.php?topic=7122.900
Audio recording while shooting in raw (MLV) has now been enabled by g3ggo. It seems like they are still working out some bugs, but it's good news!
Complete Video Guide To Installing Magic Lantern Raw On the 5d
Hi Everyone. This is a complete guide to installing magic lantern raw on the 5d. What is it? What you need to know? How to install it. How to use it. What to do with it in post.
Chris :) www.boygetslost.com
MikeLinn: Very good program to convert RAW into Cineform RAW (very small compressed raw) http://primehd.com/raw-to-cineform
@blackspot I'm not sure. Probably not continuous, but you'd get at least a few seconds, most likely.
@eatstoomuchjam What is a maximum recording time at ~2.5K at 23.976fps ?
The answer is mostly "no" to that. One has the option of either the standard scaled output or a 1:1 crop of the sensor. At 1:1 doing 1920x1080, the size is closer to super 16mm film or the BMPCC (around 3x crop). One can push that out to 2.5k, but not at 16:9 (more like 2.35:1), but that's still not quite as wide as super 35mm.
Hi. Please verify. Is it possible to capture M43 sized portion of the 5dMKII/III sensor (about 2x crop mode)? I guess, one can capture HD sized crop of the sensor continuously, and super35 sized crop for couple of seconds, but what about 2x crop, is it possible to record continuously?
720/60p 5d mk 3 RAW
Yeah - that looks really nice.. except for the enormous watermark!
@bozfx, thank you for posting that video. That is a great example of what ML RAW can do when you get the work flow right. I'm still trying to learn as much as I can about how to get the best from my Canon 50D and seeing 5Dmk3 footage like this gives me chills. The detail and color is just fabulous and on top of that very little Moire or Aliasing if any. It puts another check in the box for maybe going to buy a 5Dmk3 instead of a BMCC.
Wow! Just.... wow:
Shot on the Canon 50D with a Rokinon 85mm T1.5 Cine Lens
RAW with Magic Lantern RAW
5DIII ML Raw + RED Epic
A zombie music video shot on 50d raw in 2:3 mode with Bolex anamorphic
