regarding the options with the 7Q:
Few raw samples - http://www.alisterchapman.com/samples/fs700-f55-raw-samples.zip
And it seems like FS700 is not bad in raw.
http://www.xdcam-user.com/2013/06/stunning-fs700-raw-performance-really-impressive/
One thing I'm trying to figure out with the FS700 and the upgrade: I know that with the upgrade you can shoot 4K and 2K raw with the proper recorder, etc. But they also add S-Log2 which you can shoot with the external recorder or internally AVCHD. Internally it will be 8 bit. Right now, the SDI out is 8bit, but once you upgrade the camera they say you can shoot 4K RAW at 12 bit. My question is: once upgraded, can you take a regular (i.e. non 4K) external recorder like a Ki Pro Mini and shoot above 8 bit out the SDI in regular 1080p (e.g. for the Ki Pro Mini it would be 10 bit 422)? This would make it so much easier to grade and match with other cameras; plus I don't know how well S-Log2 in 8 bit would hold up under extensive grading.
also, check http://www.convergent-design.com/Products/Odyssey7Q.aspx
Here they give you a couple of options and a comparison table on the bottom.
@Tobsen thanks for that article. very interesting, but it says the HDMI-out is still 8bit? You've heard 10bit from HDMI or SDI? I've heard 12bit from SDI (but am still unsure whether that is 4k/2k only with a higher end external recorder: it would be great to have even 10bit 1080 from a Ki Pro Mini for now). The 20000 ISO minimum is something new I had not heard about. It's both good and bad. Good for getting more slo mo in lowlight; bad when you want to get shallow focus on a fast lens in bright daylight (we'll definitely still have to use screw-on ND filters for the lens).
@digger I meant 10bit (or even 12bit) from SDI. I think only in S-Log2 the minimum iso is 2000. On the other profiles, it should be lower. I saw a noise test of S-Log2 on the cam and it was quite interesting. Here it is:
http://blog.domisljije.si/2013/07/15/iso-test/
Noise levels are quite low. I hope I get my cam back next week so I can see for myself how the firmware performs.
latest info from Sony Europe: SDI output after FW update is still 8bit. So If you dont have a RAW recorder the ony benefit is sLog which doesn't make sense in 8bit
incl some RAW footage
new camera for 400 bucks nice ;-)
2K Raw seems to have a big moiré issue. :-/
Slow motion
The edges on 2K look terrible...hmm..
Very nice!
there seems to be an issue with FW 3.0 I found this at dvxuser.com
http://www.dvxuser.com/V6/attachment.php?attachmentid=76118&d=1378789104
