Lenses for Canon FD mount
  • 188 Replies sorted by
  • @stonebat
    I don't understand the all or none comment. I mix Nikkor, OM, MD, FL, FD, nFD, CZ, Yashica, M42, and etc. with no trouble. Is there something useful about matching up?
    @stoneinapond
    The nFD 50/1.4 isn't great wide open but stop it down even 1/2 a stop and all the ghostly halos go away. Even at that the nFD version shown above, is better than the FD version with the S.S.C. printed on the ID ring which halos even worse WO - but again is cured in one full stop click (as opposed to 1/2 in the case of the nFD). :)
    @bitcrusher
    The nFD 24/2.0 actually has better IQ than the 24/1.4L so if you don't need the extra stop that'll save you some money.
    Also the FL 58/1.2 is a good substitute for the 50/1.2L if you don't mind the extra 8mm of angle. :)
    @anyone... :)
    I have a buttload of FL/FD/nFD lenses and I like most of them. I don't think I would try to make some kind of matching set out of them for video and/or stills tho. Most are not exceptional IQ. Even the famous 85/1.2L for example is pretty terrible wide open. Way too much CA and almost all bright nFD lenses under 200mm (including L versions) halo and ghost in bright contrast. Like the Sun on shiny leaves or highlights on a pond surface. Stopped down they're better but most lenses are - better when stopped down I mean. I guess we could call it a soft-focus special effect or something. :D
    Canon makes supremely awesome long lenses but I don't have enough love for the majority of the under 200mm group to become exclusively FD. Some newer EOS mount lenses are improved - especially the L versions but without special and very expensive adapters we can't control the aperture on EF (EOS) lenses. There are a few nice exceptional FL/FD/nFD lenses to be had for sure but finding out which ones to get or leaning how to avoid the trouble spots of each, can be kinda time consuming. I'm not saying to not buy/use them or anything. They're fun lenses and I think a great for experience and learning - if you're into alt glass don't skip the old Canons!
    Here's the latest 9 Canons I sold or still for sale:
    image image image
    Canon_FDn_24mm_F2.0 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FDn_24mm_F2.0/
    Canon_FDn_24mm_F2.8 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FDn_24mm_F2.8/
    Canon_FDn_28mm_F2.8 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FDn_28mm_F2.8/
    image image image
    Canon_FD_50mm_F1.4 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FD_50mm_F1.4/
    Canon_FD_135mm_F2.5 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FD_135mm_F2.5/
    Canon_FDn_135mm_F2.8 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FDn_135mm_F2.8/
    image image image
    Canon_FL_200mm_F3.5 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FL_200mm_F3.5/
    Canon_FDn_200mm_F4.0 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FDn_200mm_F4.0/
    Canon_FL_200mm_F4.5 - http://tesselator.gpmod.com/Images/_Auctions/Pages/Canon_FL_200mm_F4.5/
    I'm selling them over at FredMiranda.com here:
    Sold: http://www.fredmiranda.com/forum/topic/985376/
    4Sale: http://www.fredmiranda.com/forum/topic/1003697/
    Although usually I do the e-bay thing. :)
    If anyone want to see some example photos taken with these just ask.
  • Always remember to add Vivitar 55mm F2.8 macro. It is very good, but doe to fact that it is not so widely advertised in web, it is also much cheaper.
  • Canon 50mm f1.4, 50mm f1.8, 85mm f1.8, Kiron 28mm f2.0, Vivitar Series 1 90mm f2.5, Vivitar 100mm f2.8 (1:1 macro) are the ones i know and which i selected based on a lot of good comments. They are all very cheap (apart from the 85mm perhaps)
  • Some good info concerning Canon FD lenses.
    Video about lenses and sample footage:
    Top FD lenses thread
    http://photo.net/canon-fd-camera-forum/00TCd1
  • The contrast and color reproduction is deferent on L glass also the build quality is very nice. If you like the look then you are kind of stuck with the bill.
    I think its cheap compared to what EF lenes go for, and the FDs are going hold there value a lot more. In 50 years most EF lens will not work anymore but the FDs will still be taking wonderful pictures.
  • @bitcrusher
    Prices on FD jumped significantly in last years. Due to m43, and, especially due to NEX release.
    Personally, I do not see a point to collect all top glass or L glass only.
    85mm F1.2L is not astonishing lens.
    I am not sure about 135mm F2 also.
    Telephoto and wide lenses gained image quality (why being cheaper) due to heavy ED and aspherical elements usage in modern lenses.
  • FD's sound like an inexpensive proposition unless you need a matching set. I like the FD image for narrative work.
    The 14mm 2.8L will put you back 1K+ or you can get a 17mm f4 for $3-400. The wide side of the FD range can give you some headaches but when you use legacy glass this is always the case. It is harder to match modern lens to FD so this can be a turn off a lot of users.
    If you have 4-5k you could get this set. Sounds expensive but it will probably double in value in another 10 years. This is the set that I am slowly building.
    14mm F2.8L
    24mm F1.4L
    35mm F2 concave f16 version.
    50mm F1.2L
    85mm F1.2L
    135mm F2
    Maybe a 200mm f2.8 and 300mm F2.8L,
  • My 50mm 1.4 is razor sharp, even wide open.
  • I kinda like fisheye distortion in photo. ACR can fix the distortion if I want to. In video I have no idea how to correct it. That's where Lumix 7-14 shines. It's rectilinear. Although it's slow at 4.0, it's the sharpest wide angle lens on m43 bodies.
    As soon as one mixes FD w/ lumix m43 lenses, he faces challenge to match them. Thus all FDs or none... I think.
  • Maybe I'll buy this sunday 28/2 :)
    Also there is 15/2.8 but I don't like fisheye image.
  • Try to see if you can find good FD 24/2.0 in good condition at a reasonable price. Also 15/2.8, 28/2.0, 35/2.0. I feel... I missed a boat.
  • I've got 50mm 1.4 S.S.C. in good shape with ciecio's7 adapter. Cannot complain. It is cheap and produce picture I like :) In addition it is manual.
    You can find these lenses (50mm/f1.4) in good shape. No big problem in Poland.
  • It's great if one has a set of FD lenses. But it's getting harder to find good conditioned FD lenses from ebay.
