Okay it looks like the consensus here is you can't go cheap on stabilizers. I don't want to get into a situation where I'm eating up time trying to balance it. That's seems to be an big issue.
EDIT: the Hague also has a really lousy system of ordering for US based customers. You can't even find out the cost until you start filling out invoices. They take your credit card then tell you how much they just charged you? No thanks Hague.
Hague is clearly not good with their friction ball system. Steadytracker is similar in concept to $5 stabilizer project from steel pipe :-) Just more advanched. Look for gymbal based stabilizers.
@ LongJohnSilver I didn't mean it is impossible to make it work. It just hasn't worked for me. Tried it with both 20mm pancake and 14-140 lens, both 24 and 60 p and still it gave me too much shakiness.
Interesting about the continuous autofocus. Keeping the lens wide with fixed focus and fixed aperture works best in steadicam shots in my experience. Any slight image correction (for example moving across an area where the lighting changes) can be done in editing - unless it's severe change of lighting, in which case yes, use auto exposure. With a planned steadicam move and a wide lens you should be able to work with fixed focus. A slight loss of focus while the image is moving is not going to be that noticeable, as long as the static parts of the shot are in focus.
It's been proven that shaken video produces lower bitrate in GH13. But it seems a lot of work to do careful balancing on a steadicam each time. I mean... swiveling LCD could throw out of the balance. Can the continuous autofocus on 14-140 throw it out of the balance? How about a mix of a bit hardware and a bit software solution?
Ok. So I exchanged my Glidecam Pro 2000 for HD1000 today. The difference couldn't be more dramatic. HD1000 is at least 2 times lighter and easier to use. It took me about 30 minutes to balance it for the first time with 14-140. And I'm only starting to learn the craft.
Freek'n nice camera moves man! You sure you don't have iMan connected up to your own self? :D
Seriously, all in one take (no cuts)... Awesome! A few clipped heads here and there but overall very professional - top notch!
You ROCK!!
BTW, a good set of macro rails might help with balancing without the need to turn any bolts. I use the Velbon rails myself - picked up a set for $20 at the used camera shop.
I tried that warp stabilizer and it does work extremely slow. And my system is pretty up to date with 10 GB of RAM and quad-core processor. I totally agree on having everything look good prior to post, and that's why I'm going to bring back my Glidecam. What I don't like about it are the controls. It's a huge pain to unscrew 8 or even 4 bolts every time you need to move your plate to reach the proper balance. I also searched both Vimeo and Youtube and didn't find a single example of Glidecam Pro 2000&GH2 with decent results. Meanwhile here's how Glidecam HD1000 and GH2 alliance may look like
Yeah, it's better to have good footage to work with initially. But I'm an avid user of stabilizing software (albeit in eyeon's fusion) and it does a wonderful job! Results can be superb with a little practice and a 2k or 4k frame to work with! There are lots of times when steadycam type devices can't be used or just for removing tripod jitters and etc. So, don't discount the software solutions completely - many of them work better than you might initially think. :)
I fully agree to points rised here. You need to have good steadicam and, more important, learn to use it. Learn to balance the rig, make fast rebalance on lense change or zooming. Understand how you must change your walking. And all people I had talks with recommend to buy proper west. Because after short periods your hand become tired and footage won't be so smooth.
I also recommend to buy this for indian stabilizers -
A lot of wisdom from dkitsov - I totally agree that it's better to get it right in the camera.
I think it's useful to understand how stabilization software works, because it gives a clue as to why software isn't always the answer. Simple software will work out the camera motion by tracking a few objects in the scene, then tilt, rotate and laterally move the picture to cancel out the camera motion; more sophisticated software builds up a map of the scene objects in 3D space, calculates the lens angle, and then warps bits of the picture to compensate for camera movement. 3D calculation gives better results in travelling camera shots, for example where the camera moves around a central object.
Whichever software you use, the more stabilization you choose, the more the software has to "move the image around" to cancel the camera movement, leaving occasional black edges around the frame, so it also has to zoom in to the processed image just enough to crop out the moving black edges. Because of that zooming, you lose resolution and also slightly negate the effect of the stabilization. There are other effects which look odd: for example, if there's a blurred frame in the middle of a sequence while the camera is moving, your eye will accept the blur because that's what happens when the camera moves. If that same sequence is stabilized, you will get a blurred frame in the middle of an otherwise stable sequence, which looks quite unnatural.
For all these reasons, as dkitsov says, it is always better to get stable footage while capturing if you can, for example with a stabilizer and with a wide lens angle, and use software stabilization only if you really need to.
It's not all bad. You can get away with software stabilization in short shots with a strong single visual point of interest, because that will temporarily distract you from the overall loss of detail in the stabilized shot. Instead of stabilizing, you can also try slowing down unstable footage, which can be very effective if it's appropriate to the video / subject (for example a handheld shot of a static object). There are at least 11 (eleven!) slowed shots in my Vimeo video in my earlier posting. Also, the tracking shot at the opening is actually a composite of four stills, which is then panned in the editing software.
Let me chime in and say I'm not a very happy flycam nano user with the 20mm 1.7. I got some reasonably good results but it's a huge pain to balance and when you do, you're either not properly balanced statically or dynamically. I'm gonna give it one last chance when I get my hands on a different, longer on the front and heavier wide lens like the 14-140 or samyang 14 2.8 (neither of which I own:( ). About cs5.5 warp stabilizer: it looks amazing, mainly because of it's ease of use compared to the usual method and it's one of the main reasons why I'll upgrade. Great tool to have. But I don't think anyone with a basic understanding is going to rely exclusively on warp and expect it to be like steadicam:) you're not gonna fool anyone. All it does is it adds another layer of stability if you need it. If you were using a shoulder rig and you want it to look more stable, you now have an easier solution. If you for some reason had to go handheld, and you have awful footage, you might just get some usable shots. For me, the main thing i'm looking forward to see how it works is the shoulder rig + warp stabilizer combo. If it gives me the amount of steadiness I want, I will hopefully be using a bit less of the steadicam which I despise balancing, I can't be quick with, can't monitor with, can't focus with, can't improvise with, can't get good audio with, can't change lenses on the fly with but in some occasions(hopefully fewer with warp), can't live without.
Oh sure, let's fix it in post... You must realize that Adobe's marketing makes certain things look way better than they really are. I have been playing with CS5.5 for the last week and you may trust me, that while the technology is short of a miracle it is very limited in it's application. Also it is painfully slow even on a fast computer. You always want to get your footage as good as you can long before it hits the post. Do not get rid of your camera stabilization system.
I have the flycam nano, and I think it's great for the GH2. Much better than the Hague MMC, which I also have. I have had little trouble balancing it on the GH2. If you do the drop test, you want about 2.5 seconds. Best idea is to get an adaptor plate so you can just snap it in, and you're ready. Then, you don't have to balance every time.
I've just ordered the flycam nano.. seen and heard a lot of good things. will post impressions when it arrives. am factoring in 5 hours to balance the damn thing, but, for the price, it appears to be the only drawback and one that should only frustrate the first time out!
I just got a blackbird. It works well with gh2 with 14-140 lens.
It is on the verge of being out of control with 20mm pancake. It's stable vertically but has side to side sway here and there. They are sending me a shorter tbar to try for the lighter setup.
It works well with my pan150. But god that's heavy.
