@ LongJohnSilver I didn't mean it is impossible to make it work. It just hasn't worked for me. Tried it with both 20mm pancake and 14-140 lens, both 24 and 60 p and still it gave me too much shakiness.
Hague is clearly not good with their friction ball system. Steadytracker is similar in concept to $5 stabilizer project from steel pipe :-) Just more advanched. Look for gymbal based stabilizers.
Okay it looks like the consensus here is you can't go cheap on stabilizers. I don't want to get into a situation where I'm eating up time trying to balance it. That's seems to be an big issue.
EDIT: the Hague also has a really lousy system of ordering for US based customers. You can't even find out the cost until you start filling out invoices. They take your credit card then tell you how much they just charged you? No thanks Hague.
I'm using a Steadicam Merlin with my GH1 - it works well, but as has been said you have to pay attention to the tutorial video to set it up correctly, and also practice a lot!
The rig is very light of course but this means you don't get so tired holding it. The Merlin is more expensive than competing products but you get what you pay for - this one was designed by Garrett Brown who created and developed the original arm-and-vest-Steadicam, and his experience shows in the product.
The Steadicam Operator's Handbook (published by Amherst Media) is worth reading too - it mostly talks about the big Steadicam rigs, but it helps you understand all the principle involved, and many of the techniques apply to the Merlin as well.
On the subject of software stabilizers - no, they are no substitute for getting steady footage in-camera, but they can help with removing small wobbles.
The best one I have found is Lock'N'Load from http://www.coremelt.com/ - works with Final Cut Pro, Motion, or After Effects.
>Pretty good price, do you have any results using that steadicam in conjunction with GH2?
Nope, all I see is good construction and good adjustable base plate. My steadicams have not good base plates, so I use slider usually, and they use offset design that strain your hand quite fast, so this is why I offered this link.
@Donnie88 I had flycam nano and got tired spending every time a 30 minutes (8 bolts) on balancing (sold ...) than bought W Ares, it takes max 5 minutes to balance ...
I have been playing with a merlin and steadicam pilot. Taking me a long time to get them working. I can use the pilot, but the merlin is still hit and miss. I'm guessing it's because it's much harder to get proper balance. I"m probably going to sell the merlin and look at something else for a hand held. I had an old glidecam before they had the better macro adjustment and will probably tgry them again for hand held.
With the pilot, I added a 3 lb platter under my quick realease to add weight for the gh2. Works nice now.
