24mm F1.4 T1.5 Samyang Rokinon official topic
  • 119 Replies sorted by
  • Oops. I was asking for 35mm. 24mm isn't out yet.
  • Are these on the market yet? Can't find much, Price? 300 euros? USD?
  • really interesting lens - I love Samyang
  • We should lobby them to add an HD anamorphic adapter like the Panasonic LA7200 to the mix. I say HD because the LA7200 was built for SD video and it shows a little bit. They would sell a ton of them.
  • Which mount version did you guys get?
  • A set of stepless Samyang 8/14/24/35/50/85/135... Wow
  • samyang needs to make a really really good 50mm f/1.4 and a very good 135mm f/2 and they'll rule the world:) that way they'll have 8mm 3.5,14mm 2.8, 24mm 1.4, 35mm 1.4, 50mm 1.4, 85mm 1.4, 135mm 2: an entire set of all manual, decent build quality lenses, excellent optically completely future proof (FF coverage) perfect for budget video filmakers. And then one could dream about the same set but with stepless aperture and packaged in a set for good discount:)
  • Yes... the front barrel extension... not so matte box friendly. I could start selling my vintage lenses at profit and switch to the Rokinons. 120 degrees rotation... how about focusing by hand instead of FF?
  • @stonebat Yes, both the 35mm and 85mm Rokinons use internal focusing mechanisms and have fixed front lens barrels that neither extend nor rotate. The 24mm looks like it's built the same way as the 35mm, so I expect it uses internal focusing as well. The Nikon (and probably Pentax) versions of these lenses have focus rings that rotate in the same direction as Nikkor lenses, unlike Sigma's lenses, whose focus rings all rotate in the same direction as Lumix lenses, regardless of mount type.
    I've found these properties highly desirable for using these lenses on a rig with follow focus and matte box attachments. With most follow focus gears, focus direction is determined by the lens. making focus ring rotation a crucial issue. In addition to being able to choose that direction by lens mount selection, the focus ring on the Rokinon 35mm rotates about 120 degrees, giving you very fine control. The fixed outer lens barrel makes it ideal for use with matte boxes and anamorphic adapters as well.
    I recently tried out a 24mm f2.0 Nikkor AI-S lens in excellent condition. It was very compact, with beautiful image quality and precise focus control. Unfortunately, I had to conclude that it just wasn't what I needed in either a video or a stills lens. Like most vintage primes, while the front lens barrel doesn't rotate, it extends while focusing, And with AI-S Nikkors, the lack of a CPU chip on the lens mount makes them unusable with the light meters in many Nikon camera bodies. The modern design of the Rokinons makes them much more adaptable to my purposes.
  • Is this lens going to be internal focusing? How about 14mm, 35mm, 85mm from Samyang? All internal focusing?
  • That's a great news. I'm in the market for good 4x4 nd filters.
  • @Tommyboy
    I hope that you could use 4x4 NDs with it on m43.
    I am working with few producers so more affordable 4x4 filters will be available.
    Check Gear category, I'll try to post info as soon as all the details will be finished.
  • It's not a problem. I could've done more research myself ;-)
    I love the 35mm one and can't wait for 24mm to come out. It looks very solid just like the 35mm one from the pictures you posted in the first post .
  • >So now since I have the Rokinon FE14M-C 14mm F2.8 Ultra Wide Lens I can say that YOU can't use any 77mm filter you like with this glass.
    Sorry, my bad, of course you can't use 77mm on his lens.
    Whole discussion is about 24mm and 35mm and I accidently thought that you mean 35mm Rokinon.
    It uses 77mm.
    Sorry again.
  • @Vitaliy_Kiselev
  • Thanks Vitaliy!
  • Other good thing in Samyang produced lenses is that they make good investment.
    I can instantly use them on my Pentax, mount on m43 bodies.
    And could mount on FF body is this become available.
  • >OOK That's good. If you look at this image the glass is not flat hence my confusion.
    All the lenses are not flat, most are part of the sphere.
    Some (called aspherical) are more complicated.
  • @HillTop1
    The sensor in the m4/3 means that the Field of View is half that of the same lens mounted onto a 35mm full-frame.
    Effectively:
    35mm Samyang = 70mm on m4/3
    24mm = 48mm on m4/3
    Note, this applies even to the m4/3 lenses, so the Panasonic m4/3 20mm Pancake on a GH2 will have the equivalent FoV as a 40mm lens on a 35mm full-frame camera.
  • OOK That's good. If you look at this image the glass is not flat hence my confusion.
    Thanks for clarifying!
    1500 x 1500 - 175K
  • >Is there a UV filter for Rokinon FE14M-C 14mm F2.8 Ultra Wide Lens for Canon?
    What do you mean?
    You can use any 77mm filter you like.
  • @HillTop1
    I suggest to look at
    http://www.personal-view.com/talks/discussion/688/dslr-hd-video-tutorial-videos
    Different fixed lenses have different FOV.
    You can look at m43 as film where you cut central part, so you'll instantly understand that 35mm FOV on full frame and m43 is quite different (2x different in photo mode) :-)
  • Is there a UV filter for Rokinon FE14M-C 14mm F2.8 Ultra Wide Lens for Canon?
  • @HillTop1
    35mm is 70mm in micro 4/3 world.
    micro 4/3 is 2x crop sensor.
  • @Tommyboy, yah.
    I am still a little confused about the various focal lengths for non-micro 4/3 lenses and how they match up with the micro 4/3. So is the Samyang 35mm f1.4 for example be 70mm or will it stay at 35mm?
    If it's 35mm, why does the 24mm gets up to 48mm on micro 4/3?
