@inqb8tr no that i think is normal i'm talking about frames "jumping" more than it's supposed to while shooting handheld with a non-stabilizing lens
@GravitateMediaGroup What settings do you normally have your standard picture profile setup to in terms of NR, contrast, saturation and sharpness?
issues of image "Shacking"
Do you mean like choppy movement, like those wooden bars at 0:15?
Quick test not to see the quality of image because i already know it's great but that was to see how Moon 5 works while used with shoulder rig and my 45mm olympus lens. Since the first Driftwood's hacks i always had issues of image "Shacking" for a lack of better word especially on the edges of frame while using handheld or even with a shoulder rig and i know a few other users have adressed that problem without solutions. Didn't have this problem with flow motion so i thought that had maybe something to do with gop. (Gop3 handles motion better than intra?) Now i can't confirm this(need more testing) but i must say that i am surprise that this problem is (almost) gone with moon. This was shot using an ND filter as well.
Loading up Moon trial 5! I've got to shoot the Curator walking around the ruins where I was doing jib shots before, with the jib this time too, results tonight!
@inqb8tr so I assume it would be best to put it into a 23.97p timeline in FCP X?
@Imackreath You are shooting at 23.976.
Also, if we are shooting at 24p...do we put this into a 24p timeline into FCP X or a 23.97p one?
@driftwood What setting do you normally have the standard profile set on in terms of sharpness saturation contrast and NR?
Here's a quick lower light test with Moon 5. ISO800, 24P with 1/30 shutter Standard -2,-2,0,-2 Rokinon 85mm at T2.8 As you can see, children were just in the area and I thought it provided some detail and color for a quick test. Paasword: Moon
@driftwood I shot some Moon3 through my Kowa yesterday . . . wow. Gorgeous. I can tell I won't need a new camera for a VERY long time. Moon is exactly the look I've been waiting for. Your other stuff has always been good, but something about Moon just hit the nail on the head, IMO. Thanks, and looking forward to the final Moon patch.
drop files from cam SD into a folder, drop into vegas, makes some tweaks if needed, export. I keep everything to a minimum
the grades in this edit are not would I would typically do, just through it together pretty quick
@GravitateMediaGroup Your standard looks like nostalgic to me, and very smooth :) what is your workflow for editing, output, please?
some clips fade from ungraded to graded
another note is that trial 2 in this edit MIGHT in fact be trial 3 footage, I've had so much going on recently my organization has gotten a little shaky. lol so just keep that in mind.
i'm also pretty happy with my HDR experiment ; )
@eyesoul standard is the best anyways
do you use a variND with your sigma? if not, it's a MUST ; ) tiffen makes a nice & affordable one
oh yea excuse the bumpy slider movement,it's not the hack.
A quick 3 shot test of Moon trial 5.In all fairness I shot my test with the wrong settings or should I say I shot with my stills "standard profile" by mistake. I think it was something like 0,+1,0,0 .I guess if you like a more baked in look this may work for you but I usually have my settings dialed down.Clips straight from camera,shot with Sigma 30mm 1.4.Even though I screwed up my settings I like the image quality & can't wait to go back out with the setting.
Driftwood do you use -2, -2, -2, -2?
should have a mixed edit of trial 2-5 with a variety of some graded clips some not, within the next 24 hours. to be honest, all of them look great, I guess it just comes down to improving stability for different camera settings. I've yet to personally have any issues, but I don't shoot 720 or HBR and so on. For fun I did shoot a clip with HBR and didn't find it to looks as nice and appeared to have less detail more noise.
UPDATE: after watching a couple times in a row, my Favorite is moving from 3 to 5. the clips I shot of the wind chimes vs anything else from previous trials sealed the deal ; )
@danieivy or you can just color grade your footage to get the same result. drop the saturation a pinch and lower or raise the contrast to what you're trying to achieve.
Its a bit over the top (OTT) its full max for in tight to medium wide scenes - It does tend to break up a tad in wide hi-detail shots with poorer QP though. moon tries to spread the bitrate across the picture more resulting in higher average QP results for all kinds of scenes.
@driftwood What's OTT? Either way, I'm loving it for day and night shots. Your work is much appreciated. When do you sleep?-damn you're productive!
Flat 4s if thats what you mean. Its OTT and isnt so good at wide detailed scenes. In broad daylight Boom is incredible.
@daniellvy I think I read somewhere that some people are putting settings at all -2 to get flat look (with exception of Saturation, which some are setting at 0). I could be wrong, so maybe some of our experts can chime in here to confirm or refute. Have you tried Apocalypse Now Boom v.1? - I love it. If I remember correctly, it was designed to create "flat" footage...assuming I read the description properly. I'm not super technical, but think this is accurate. Maybe @driftwood can chime in to confirm/refute Boom being designed to be flat. I also love how it grades so easily and nicely.
Tom's been busy...
