@matt_gh2 dial down the saturation, and the contrast. Try to shoot using a profile that doesn't process (and bake-in) any film curves. Basically as close to something that resembles a raw image. Also, if you manage to be able to squeeze it into the 5 stop range I discuss in the Expose in the Zone tutorial, you get an even flatter image.
This is why I say shooting Intravenus is like shooting Kodachrome. Kodachrome only had a 5.6 stop Dynamic Range. Unlike today's 14 stop film. I'm used to that from my days shooting stills. But with today's technology I don't see that as a limitation except when shooting in available light. I'm torn between my love of ISO sensitivity going up, and having to work around limitations. Having to work around them makes you better. Better sensitivity and wider DR are great to have. But I'm a fan of those who paint with light. And who paint again in post. I'm excited for the new tools. But I feel for those who will learn on them. Most will never do anything interesting with them. Like the moron's who buy RED cams thinking that it will instantly make them a Cinematographer.
@shian +1 on Canon comment. People just trust the name. Glad I found the GH2 and personal-view.com. it's all good - we'll just keep rocking the house
@shian - Love that anecdote, for sure. Local DP just ditched Canon after seeing what the GH2 could do when I and my coworker were pulled in on a music video with him. Cuts stunningly with his F3.
@matt_gh2 - In the Canon world it's Cinestyle. Here, in GH2 land, most shoot with most setting in the picture styles set to -2. I shoot standard -2 across, except for saturation I believe.
@shian What is shooting flat? What is benefit? Thanks
@Mirrorkisser Yes. I love it for everything. No problems on wide shots. It's my all-around favorite. I don't know if @driftwood and @cbrandin can get any closer to film than they have with Intravenus... but if they never get any closer than this, I won't care. I love the way the footage looks.
I just shot it side-by-side with 5D Mark II and Mark III cameras, as the C Cam, and the Canon guys all snickered at me. They were gonna show me that my little camera couldn't possibly hang with them. I was brought in, mainly as a joke, and I knew it. And at the rushes viewing, the producers and the director blew up at the DP because they wished all the footage looked like mine. They wanted to know why the GH2 wasn't considered the first choice for A and B cam. I just shake my head at this point. The indie world has it's head all the way up Canon's ass. In the end; I was the only one laughing.
@ shian so do you use Intravenus on a regular basis now? Have you experienced any problems with wider shots with it?
My mistake was assuming everyone knew why to shoot flat. I'm trying to find the numerous threads where I (and others) have explained this, and save some typing.
The impetus behind this thread was the assumption that shooting flat in 8 bit was a mistake. A mistake because of the "lack of color information." Which is just a wrong assumption.
you shoot flat because there are some things you can't undo in post. You can easily add contrast. You can't take it away and have it look very nice. You can't undo the saturation bleed that comes from emebedding rich colors into the image in 8bit, 4:2:0. You have ultimate control over your image in post by shooting as flat as possible, and THEN grading in 32bit. Which goes back to what I said earlier, "Which is why you shoot flat. Take the burden off the internal engine of the camera, and place it on the massive processing power of your PC, and a 32bit color engine. Everything I've done in ColorGHear is based on this."
"The reasons for shooting flat are separate."
@balazer If/when you have the time, it would be greatly appreciated if you could elaborate.
Thanks in advance.
Yep...8 bit 4:2:0 color really is nonsense in 2013...
Tommyboy, I use Vegas 10... What I write here is for luminance levels. The story is pretty much the same for chrominance levels.
With 8 bits you can have 256 different combinations. We use 8 bits to represent the integers 0-255. 8-bit video levels means black is 16, white is 235, and everything in between is a shade of grey. To keep things simple, values below 16 and above 235 are invalid. 8-bit full range means black is zero and white is 255.
When you set your Vegas project to 8-bit, the 8-bit values decoded from your input format are used as-is, with no expansion or contraction of the ranges, and then converted to 8-bit RGB for working, and converted back to your output format upon rendering with no expansion or contraction of the ranges. So when your Vegas project is set to 8-bit, if your input format is video levels (like the GH2's files are), then you are working in video levels. If your input format is full range, then you're working in full range. Output formats like MP4 and MTS are supposed to be video levels also.
In 32-bit mode, the full range is still 0-255 as far as I know, but now you are working with decimals instead of integers. You can have values with more precision, like 20.235453. When you choose 32-bit video levels, the input is decoded and converted to RGB with no expansion or contraction of the ranges. It's essentially the same as choosing 8-bit, except you are working with more precision internally. When you choose 32-bit full range, the input is expanded out to the full range when read, and compressed down to video range when rendered: black at 16 in your input becomes 0 in the working space, and is converted back to 16 upon rendering.
Practically speaking in Vegas, you have a few different ways of working. If your PC is fast, set the project to 32-bit full range and a gamma of 1.0. Video previews in the Vegas window and on an external computer monitor will show the correct levels. If your PC is not so fast, do your work in 8-bit mode and render in 32-bit mode. Choosing 32-bit video levels will make all of Vegas's filters behave exactly the same as they would in 8-bit mode, except of course that they work with more precision. If you prefer to work in full range, when set to 8-bit mode you'll need to put a Levels filter with the Studio RGB to Computer RGB preset at the beginning of every filter chain and another Levels filter with the Computer RGB to Studio RGB preset at the end of every filter chain, and then disable those filters when you switch to 32-bit full range mode. It's a bit complicated, and I don't suggest working that way.
Vegas will only display the levels correctly if you have everything set correctly. When the project is set to 8-bit and your input format is using video levels, full-screen previews on a computer monitor will only be correct if you check the "Use Studio RGB" box in the Preview Device Preferences. Video previews in the Vegas window will only be correct if you add a Levels filter with the Studio RGB to Computer RGB preset at the end of the filter chain. Disable the filter when rendering in 8-bit mode. The same rules apply when the project is set to 32-bit video levels and your input uses video levels. If you set the project to 32-bit full range, previews will show the levels correctly with no need to add a Levels filter or check the "Use Studio RGB" box.
There's more info here: http://www.glennchan.info/articles/vegas/v8color/vegas-9-levels.htm
shian, it makes no sense to say that working in 32-bit floating point is a reason to shoot flat. You probably wouldn't want to shoot flat if you couldn't work in 32 bits. But having the ability to work in 32 bits doesn't mean you should shoot flat. The reasons for shooting flat are separate.
@shian: you made me test; I see no difference (in a well lit scene) between 16bpc and 32bpc processing. On the other hand 16bpc is only very marginally faster than 32bpc float (I was making assumptions which don't turn out to be true) so 32bpc it stays.
Agreed on the RGB444 master, which on Windows really means Uncompressed. DNxHD I'm staying away from, at least until they fix their colorspace conversion bug in the 2.3.x release.
Without getting too technical: it just means you have more colors available to try and accurately display the image. Those of us who remember the early days of designing pages for the internet (14.4k modems) and often being confined to displaying gifs with 256 colors vs today with PNGs containing millions of colors. It's not too dissimilar to that. this wiki page helps demonstrate that.
http://en.wikipedia.org/wiki/Color_depth But what working in floating point (32bit) color gives you is basically the ability to sort of paint over the top of the given image, and fill-in the blanks. It's a fake way of adding more color information to your images. It doesn't really add anything, but it prevents the image from breaking down the way it would in 8 bit. You are essentially airbrushing fine detail onto a course image.
Which is why you shoot flat. Take the burden off the internal engine of the camera and place it on the massive processing power of your PC, and a 32bit color engine. Everything I've done in ColorGHear is based on this.
Hi @Shian In Sony Vegas
"8-bit Performs video processing using 8-bit arithmetic and in the video (studio RGB, or 16-235) color space.
32-bit floating point (video levels) Performs video processing using 32-bit arithmetic and in the video color space.
32-bit floating point (full range) Performs video processing using 32-bit arithmetic and in the full-range color space."
I'm still trying to understand the difference between video levels and full range. Any advice from your side would be appreciated.
Don't listen to Philip Bloom if you ever expect to surpass him.
@pixcanfly - all your questions can be answered here http://www.colorghear.com/helpful-links under monitoring.
@radikalfilm you'll need 32 to fix the banding, and you'll need a 444 codec to not lose it. Once you go back to any 8bit/10bit format you'll get banding.
@FilmingArt the macro blocking on vimeo is from vimeo compression - the ProRes versions of all my videos are pristine.
@shian For ProRes 444, ae working space should be REC709 or REC709 16-235? My final output is for HD broadcast. I will be outputting from FCP7 to Digital Betacam
A finishing question for AE (or other tools that allow this choice): For hacked GH2 sources (GOP3), would a 16pbc project offer less real grading room than a 32bpc project? 16bpc of course renders faster. I would not ask that question if the source was 10/12bit depth. I find I'm fighting banding (my expectations are rather high though) at every step in the filter stack, and it's a balancing act. I suspect that's all an 8bit source can give me, not that integer 16bpc induces artifacting.
To get more specific of the level of detail I'm talking (and maybe share a tip), after I'm done with grading/finishing at 16bpc with no visible artifacts, if I render out a master to an intermediate 10b YUV format (ProResHQ/DNxHD) I will get this (subtle) banding/artifacting. Not so if the master is rendered out to 10b Uncompressed RGB. I could share stills if need be.
@shian So Phillip Bloom and several other Dslr dudes always mentioned to just use Pro Res Lt, I am assuming that for grading purposes you should be using pro res 444?
I need to look into this more as I have Never seen this. Also I seen a video on your vimeo and noticed some macro blocking so can't say at least on the surface I see a big improvement over the footage I am shooting/editing.
yes. you can work in 8 and 16 if your system chokes on 32, but always render in 32 to a 444 codec.
@Shian under color setting depth in AE project setting we should always select 32bits per channel (float)?
For starters, if you insist on finishing in FCP, change your sequence settings to this:
Or graduate to a professional workflow which I have outlined here:
and discuss further here: http://www.personal-view.com/talks/discussion/comment/55553#Comment_55553
                  I edit in FCP7 and also grade in it. What can I do there to achieve the best possible bit rate? Learning a new NLE in the middle of editing projects is not something I have the time for especially when all of My projects and workflow for years with FCP have been fine. Many industry personal still use FCP 7 , so what can we do?
Thanks
found roughly what i was looking for in here: http://www.personal-view.com/talks/discussion/737/gh2-hack-myths-and-realities
sorry to go off topic.
