I've always transcoded MTS files using 5DtoRGB - only problem with this is that it doesn't export the sound recorded from the GH2.
Is there a way of also exporting sound recorded from the internal mic of the GH2?
Most NLEs will let you drop both files into a timeline, then split the audio from the video on the MTS file.
@BlueBomberTurbo So I can drop the MTS files into Final Cut Pro 7 without transcoding?
