Flow Motion VS Orion v4b VS Sanity?
  • I'm trying to decide between using Flow Motion or the Sanity hack. I'm currently using Flow Motion. Has anyone used both for a decent amount of time? What are your thoughts?
  • 41 Replies sorted by
  • Using both. Sanity for weddings, concerts etc where i need maximum quality, stability and long recording times and Flowmotion in personal projects, music clips, short films where i care only for quality and stability. Love them both!!!!
  • Especially FlowMotion in 24p mode is a killer!
  • I consider both core settings. IMO Sanity is a tad better in low light and cuts better with camcorder video. Flow Motion handles color a little better, especially blues and is better around water.
    If I was going to be stuck with one or the other, it would be Sanity...but not by much.
  • Thanks for the replies, I think I'll give Sanity v5 a go.
  • sanity is amazing in low light flow motion is better all around
    I have been testing sanity 5 a bit the past few days and have been seeing weird blotching spots with a sandisk extreme pro 95mbs card. As far as minimal noise in low light, it is probably the best i've seen out of all the patches, which makes me think whatever it's doing to reduce noise is causing blotching in other areas.
    I will probably load flowmotion back onto the camera, and keep a 2nd SD card with me with sanity for low light situations.
  • Hmmm, the reason why I question Flow Motion is because of the weird diagonal noise patterns that Roman talks about in the description of this video, that is referring to other videos that he has uploaded. Click on the link that for this video and you will see what he is talking about by viewing his flow motion videos. Otherwise, I do like Flow Motion.
  • @anthonyw I just took a look at that video and finally spotted what I think he's referring to: At 00:15 there are some short white diagonal lines just above the man's collar. I'm confused though, because this video is labeled "Quantum v9b", though the text description claims that he's only seen this artifact in Flow Motion v2.02 footage. Although the footage is downloadable, it's been transcoded to MP4, which makes it impossible to determine what the source of the diagonal artifacts may have been. If he can provide examples of the original, unedited footage, I'd be very interested to analyze it.
  • Lpowell, anyway to adapt the low light ability of sanity 5 into flow motion? that would make flowmotion "THE" ultimate patch IMO. Or is there any settings I can adjust in ptools to help flowmotion achieve less noise? There is nothing wrong with FM one bit, and it is by far my favorite patch, i'm just wondering how sanity 5 has much less noise in low light compared to other patches.
  • @GravitateMediaGroup Low-level noise is generated by the image sensor and effectively amplified by the ISO setting. While a patch doesn't have the ability to produce more or less noise in an image, it can have an effect on how noticeable it is. In extreme cases, (such as the unhacked firmware) inadequate bitrate can smear the details in a way that makes them look less noisy. On a more subtle level, the Quantizer Matrices used in a patch can suppress the fine-grained distinctions in a region of noise.
    Both Sanity 5 and Flow Motion v2 use individually customized Quantizer Matrices designed to suppress highly detailed chroma noise. This helps smooth out low-level gradients, such as shadows and dark skies. The drawback is that the lack of chroma details can sometimes make dark colors look blotchy. To minimize this tendency in FM2, I customized the luma matrices to preserve the fine details that are lacking in the chroma matrices. This technique correlates well with the eyes' greater sensitivity to luma details than to chroma.
    Judging from the two patches' different Quantizer Matrices, Sanity 5 will suppress ultra-fine details in both chroma and luma channels relatively moreso than Flow Motion v2. In cases of very rapid motion, I've found that suppressing fine luma details can produce noticeable macroblock artifacts which are partially smoothed over by encoder's Deblocking Filter. My hunch is the unhacked encoder was tuned to work this way to compensate for its inadequate bitrate.
    With Flow Motion v2, I had enough bitrate to eliminate almost all traces of macroblock artifacts solely by preserving the ultra-fine luma details. Since I no longer needed to use the Deblocking Filter to conceal macroblock artifacts, I was able to use it to smooth low-detail gradients instead. This is one of the core techniques that makes FM2 look and perform the way it does.
    From a broader perspective, what this analysis revealed was an inherent trade-off between noise suppression versus artifact suppression. Flow Motion takes a zero-tolerance approach to macroblock artifacts, and is less concerned with suppressing low-level noise. This likely reflects my own preference to shoot at the lowest practical ISO setting using very fast lenses, rather than underexpose or use higher ISO settings that incur more noise. With largely static scenes, however, macroblock artifacts are less problematic, and underexposed areas may benefit from some noise suppression of the ultra-fine details.
  • I did a quick side by side low light with sanity 5 and Nebula v7 sharp2. Sanity 5 had alot more artifacts which I had always noticing but wasnt sure of whilst Nebula had finer grain. Sandisk 64g card. Sanity 5 looks great in well lit situations though.
    sorry off topic but I was curious as people say sanity 5 has better low light? I didnt really see it myself. I'll do a comparrison with flowmotion next.
  • This is Sanity 5 in a low light situation, in a very simple production. I used some power masks to crush the blacks and a light blur to combat blotchy noise in areas of no interest. The client was very happy with the result and is strongly considering ordering a DVD release of the whole concert, to be shot with 3 cameras.
  • @Lpowell Thanks for the explanation, you explained it exactly what I assumed sanity5 was doing to hide noise. I noticed really bad blotching in my footage and it actually ruined 3 or 4 nice clips I shot the other day, so basically I'm done with sanity 5.
  • I guess I'm sticking with Flow Motion then... Thank you for the replies!
  • @TraumManufaktur with due respect but GH2 is no good choice for low light shots in general. For commercial use I would recommend to rent a FS100/700. There is still a lot of noise in the dark scenes, clearly visible at 5:35ff in the background.
  • @peaceonearth For the reportage & web delivery, the Sanity-powered GH2 did the job. If I've had to rent for that, it would never have happened. It empowered me to get a new client and a follow-up job. For the DVD production, I'll rent equipment and turn the GH2 into a B-cam.
  • Why rent higher end equipment if the client was happy with what he saw from the GH2? He may like the GH2 shots better ;)
  • @mee Cause I don't have 3 GH2's. Seriously, I get that striving for perfection, but story and connection to the audience comes first. I hope to get better with each shoot, I don't call myself Cinematographer, yet. While I do this, I strive to give someone an audience through my work. I could have left out the last song, where there was literally no light, and I would have passed as a better cameraman. Yet this was the best piece, with the highest emotional charge.
    Back to topic, I often don't know what situations will be like, what light and so on. What Sanity 5 gives me is confidence to get results that are usable for delivery, images that add to the story and don't distract. When there's a better tool at my disposal, I use that.
    Funny no one commented on the sound of the internal microphones capturing the chants. Tascam DR-40 should arrive tomorrow, paid for by this job. Cheers, now go shoot some film that have meaning to someone.
  • Hmmm, I am getting the diagonal noise on my footage too. Any chance of an update to resolve this? The two patches that I like are Flow Motion and Orion v4b, but the Orion recorded files are just too big. Flow Motion seems to be the perfect balance, except it has this weird artifact after exporting. Sanity seems to cause footage to look dull.
  • I think I will try converting to prores before editing, maybe this will cause the defect to not occur when exporting? Has anyone else dealt wit this?
  • @anthonyw
    if you real Lpowell post you will understand.
    and as far as sanity making footage look "dull" Isn't that the aim to help color grading be more efficient? or do you mean it has a lack of detail?
  • @anthonyw At this point, I've only seen only a couple video samples that showed something that like a diagonal artifact, so I'm just as mystified as everyone else. That footage had some very short white lines just above a man's collar, but since it was transcoded to an MP4 file, there was no way to determine what the source of the artifacts may have been. I asked the poster if he could send me a sample of the original footage, but haven't heard back from him.
    Since these artifacts seem to occur only with certain video editors and/or decoders, I'm inclined to suspect that Flow Motion v2 may only be a messenger of bad news about defects in those decoders. In the Flow Motion v2 thread, @fredfred27 uploaded an example of footage that decoded properly in Adobe After Effects CS5.5 but showed artifacts in CS6. That is indeed suspicious.
  • @anthonyw The artifacts mentioned in those videos are not ones I have noticed in my own testing with any setting, including Sanity 5 and Flowmotion 2.02 (as well as dozens of other settings). I will not say they cannot be created by certain combinations, but I have not been able to find a combination to create them yet.
    As far as lowlight performance for Sanity 5 vs Flowmotion 2.02, here is a 200% zoom in on a crop of a B-frame from each in 60P SH mode.
    1440 x 900 - 863K
  • @thepalalias I think you mentioned that those frames were shot at ISO 12800? In that case I wouldn't describe it as "low-light performance" but as "unusable footage". While I tested Flow Motion v2 at ISO 12800, it was only to confirm reliable operation. For a practical low-light test, I'd suggest recording 3-stops underexposed at ISO 1600.
  • If anyone's interested, I just posted an HDMI vs Sanity 5 comparison over in the Sanity thread.
    http://www.personal-view.com/talks/discussion/comment/93366#Comment_93366
  • From this I'd say both hit the limits of the encoder we have, just in different ways. Flowmotion is smoothing out some noise but that makes macro-blocking more visible, while Sanity is more grainy, but that covers some of the blockiness.
