Ultra cheap multi camera studio solutions
    • Audio and video hardware compression card, using advanced standard H.264 video compression algorithm to achieve excellent image quality and high compression ratio
    • 4 channel 1080P(25,30)/1080I(50,60)/720P(25,30,50,60) HD-SDI video inputs
    • Support up to 1080P realtime live view
    • 4 channel full-HD video realtime compression, support dual-stream
    • 4 channel G.711 audio compression
    • Support motion detection, video loss and camera masking function; support OSD, logo overlay, video frame rate, frame rate dynamic setup and etc
    • Support RAW video and JPG snapshot function
    • Support 1 channel 19201080 HDMI output or 1 channel 12801024 VGA output with 1/4-window display.
    • PCI-E x1 port, compatible with all Dahua’s compression cards
    • SDK in Windows OS or Linux OS compatible with the previous released version, fluent data interfaces and suitable for the 2nd development
    Full specs PDF - http://www.dahuasecurity.com/download/DH-VEC8004HD.pdf
    Price: about $370 shipped
    http://www.aliexpress.com/item/Dahua-hdmi-video-capture-card-pci-express-dvr-cards-VEC8004HD/656264932.html
  • 3 Replies sorted by
  • Of course, it is intended for security cameras :-)
    But can also be useful for some internet applications if you have guys who can use SDK.
  • PCI-E x1 port does not have the bandwidth for more than 1x HDMI 8-bit 4:2:2 signals. I had a long with Blackmagic a few years ago about this. This is why their 3D capture cards are pcie x4
  • @zcream
    And after this it is good to read specification :-) This thing is making hardware encoding, so it has more than enough :-)
    Plus you must always specify PCI-E version.
