Has anyone experienced the following things?
  • Hello everyone. Has anyone experienced the following things? I've been trying out the the sedena a settings patch and have experienced a few things. On several occasions my viewfinder with flicker off and then on again. Also, after recording a few minutes, on one occasion, the camera display said it had gone in to sleep mode. That file was lost. Are these things that I can trouble shoot. I'm sure it's probably something I'm doing. I'm using the best class 10 cards on the market. Any thoughts or ideas? Thank you!
  • 2 Replies sorted by
  • How is your battery and have you cleaned the connections inside the camera and battery?
    To answer the question, no, I've never had it happen.
  • Battery was at full charge. I have not cleaned the connection. Is it possible this could happen if I'm rolling the camera longer than the hack or camera I guess could handle. I think I read that some of these high bit rate hacks won't run for more than a matter of minutes or so. ?
