Tested my vintage Isco Göttingen Kiptar 2X anamorphot. Attached it to a Canon FD 50mm. It's razor sharp to the edges!
how much did you pay for the lens?
Here is a picture (it's an ebay pic not of the actual item) of the lens I have located in a local shop.
The text string is identical .. This one looks older
Here is some pictures
Sure i'll post pictures later. Also ordered a 75mm clamp from Ebay - we'll se if that works
@Beeldlab and @Jokieone, could you please post an image of your actual lens.
I've found one at a local photo shop .. very big .. my searches on ebay show a couple of different models with the same identifying text. I am wondering which one you two have.
The one I have found is 'Isco-Göttingen Anamorphotic-Kiptar 2X'
It's 18cm long at it's shortest .. 10cm (D) front barrel, 6.5cm (D) at the rear .. and 2Kg (guessing)
Sorry if necro - but what clamps did you use to mount it. I have the same lens and I'm having difficulties mounting it :)
Great, Hugo! I like the look of that lens!
