Pros and cons, Which one do you prefer and why? I'm using cluster 6 right now.
Are you in the US or Europe?
24p gives the best results... However, sometimes you need to shoot in 25p (especially in Europe) and the good thing then is that the GH2 sends a proper signal for ProRes recording, which is better when recorded externally.
I prefer 24p when I need 24p and HBR when I need 30p. Did you really expect a different answer?
Thanks for the answer. I'm in the US. So its just a frames per second thing (24p/30p) no difference in picture quality?
why dont you give it a try by yourself side by side?
There is a difference in picture quality. 24p has better picture. But when you need 30p (or in my case 25p) there's not much else you can do, right?
Didn't notice much difference when I tried HBR. Was just wondering what other people thought about this issue.
So maybe use 30p whenever you're shooting something with a lot of motion in it and 24p for the rest?
Can 24p and 30p footage be easily combined into one file in say premiere pro?
Gabel. re: However, sometimes you need to shoot in 25p (especially in Europe) and the good thing then is that the GH2 sends a proper signal for ProRes recording, which is better when recorded externally.
This interests me! Are you saying one can record 25p via external recorder ? Using HDMI. I thought the HDMI was hamstrung on the GH2 for Progressive?
The HDMI has a strange pulldown sequence in 24p, but the output is clean in 25p (sending PsF), so you can record to a Ninja or the like and tell your NLE it's progressive. Keep in mind that you still need to record in parallel to a SD card, or the output looks terrible.
I haven't tried HBR yet, but from some of the patch-specific threads it looked like it was lower quality than 24H. I have a project that needs to shoot 30P that's coming up in a week. I thought perhaps I'd use 24H at 80% and record audio separately. But with HBR I could record right into the camera, right?
For a 30P project, how significant is the quality issue between 24H @ 80% and HBR? Any patch recommendations for shooting 30P?
Thanks!
@DouglasHorn In my view, 80% Slow-motion conformed to 30p showcases Flow Motion v2 at its best.
Thanks Nomad, very interesting, Do you know how the ProRes file of HBR 25P from a ninja stands up against something like flowmotion 2. I need to do long takes so have been using settings that can span? I'll stop now as I'm probably getting off topic
So, open a new one ;-)
I'll compare it later today or tomorrow and post a differential.
I love when people make generic sweeping statements that 24p has better picture quality than 30p. You can achieve almost the same bit rates with either one and you will be hard pressed to show a difference in compression in all but the most strenuous situations.
I wouldn't use 24p or 30p for motion. 60p works much better for that.
Really it comes down to whether your final product will be rendered in 24p, 30p, or 60p. If you are rendering to 24p then you can shoot 24p and use it natively, shoot 30p and slow it down to 80%, or shoot 60p and slow it down to 40%.
If you are rendering to 30p or higher then there really isn't a great reason to shoot in 24p.
If you render to 25p then the HBR and 720p @ 50 FPS mode(Slowed down to 50%) will work well.
Trying to mix frame rates without doing slow motion is much more detrimental than compression could ever be.
@mpgxsvcd thanks that was the answer I was looking for. BTW how do I shoot 60p on the gh2?
Besides image quality, 24p and 30p have different look and feel. I wouldn't call one is better than the other. It's like saying red is better than blue.
@whynot: Yes, recording regular 25p out from the GH2 to the Ninja is no problem at all.
Switch to NTSC and use 720p60.
@LPowell - Thanks. I currently have Flow Motion v2 on my cameras, so I'll test and probably stick with that.
@mpgxsvcd - Agreed. You'll probably get the best results when you shoot with your intended end result in mind. In the case of my project, there will be a lot of motion and the final will be rendered at 30P. I may also shoot some shots in 720 60P so I can slow them down and show the motion better.
The end of the video below has a slow motion 30p clip and then a 60p slow motion clip. The 30p clip is ok but I like the look of 1/120th shutter with 60p for slow motion much better.
Also, you should note that a lot of Fluorescent lighting will prevent you from using faster than 1/120th shutter speed. You get the same strobing affect because of the rolling shutter that you do if you try to use a flash with a rolling electronic shutter. This is the reason that the flash is disabled on the new G5 when you use the electronic shutter mode.
Put it in SH mode.
Thanks, SH mode. Got it!
24p or 80% Slow Mo (but its without Sound) REC modes comparably offer more than HBR. HBR 25/30 and 720p modes don't stand up to the picture quality of 24p due to the nature of picture resolution, memory resources and the way the GH2s encoder is setup to maintain hi quality 50/60 fps. HBR (Hi Bitrate Recording) is just a hack by Pany to yield a half decent looking 25p/30p picture from a encoding/decoding implementation that is 2-3 years old. Yet you can get achieve nice results if you work to its limitations.
I just got a second hand gh2 and started experimenting (bkmcwd Valkyrie 444 TYPE-ZERO2_Candidate1.5b) I switched between 24p and HBR. the result seems quite obvious (watch hand), more aliasing on the HBR mode..
