Vitaliy, this one is plastic knob. I don't like the weak knob.
@PixCanFly , thank you very much, this is a great thing.
@PixCanFly , do you have a link to that raiser ?
Is it still possible to get deals or set up group buys on Cinematics Matte boxes?
Can consider a riser for second set of rods to adjust the mattebox both vertically and horizontally. This is riser is not too expensive and it will allow you to adjust the mattebox position to any camera setup. Anyway, I think all these mattebox are made too BIG and heavy for dslr shooting. I found the weight and size of Genus mattebox the best for dslr, but the Genus is expensive.
Here's a question: does anyone use the two filter trays on their Cinematics matte box with 4x4 polarizers, to achieve a variable ND effect? Any reason why this wouldn't work as well as prefab variable NDs that screw directly onto the lens? My hope is that it'll be much more ergonomic, allowing me to adjust ND level without reaching awkwardly in front of the matte box to rotate a lens filter.
I just ordered one of these myself. I'd have liked some control over vertical configuration--like on the much cheaper (though poorly built and poorly featured) FilmCity matte box, which I presently own.
I understand that generally people center matte boxes vertically by adjusting the height of their camera. However, for people with battery grips or with additional gear mounted under their camera (in my case, a huge red bolt attaching the bracket of a Varavon viewfinder loupe), most baseplates won't go low enough to match the standard matte box height.
I plan to remove the red bolt supporting my Varavon viewfinder, and use my Fotga quick release plate to hold it directly onto the camera. That should let me bring the camera down low enough to match the center height of this matte box.
I have to say that it is pretty quick to set up. My only issue is height. My 14-140 is almost touching the top edge and then I got one of these... http://www.bhphotovideo.com/c/product/770449-REG/SHAPE_RODSUP3_Double_Sliding_Rod_Block.html My lens was now too low even with the block at it's smallest height adjustment. I've heard that the ReWo cage is a good match, but they are out of stock. I would say for the money, this is a very good MB and I've used Chroszeil and the like in the past... Not saying it's as good, but for that price, you'd be crazy to expect it to be. Just have some way of adjusting height of your cam to match the ring's center.
Nope, just use camera base with adjustment. Like Lanparte. Most bases allow adjustments.
Does anyone know if has vertical height adjustment?
