12-35mm F2.8 Panasonic lens topic
  • 492 Replies sorted by
  • I assume you are right. In comparison with most APS-C lenses the distortion of Panasonic lenses is very low, and that seems to be good enough. There are probably not that many people who shoot architecture on m43. And correcting distortion to 0% would take away some focal length. For photos I can correct the Olympus 12mm distortion in post, just not for video.
  • In my experience neither the 14-42 nor the 14-140 zoom have zero distortion at their widest setting
    My understanding is that Panasonic does not care much until distortion is below certain number.
    In fact, it is absolutely possible to perform almost perfect software correcttion for distortion.
  • In my experience neither the 14-42 nor the 14-140 zoom have zero distortion at their widest setting, neither in photo or video mode. Both lenses have the latest lens firmware and both lenses distort equally on both GH2 bodies I own. All reviews of these lenses that measure distortion in photo mode state a moderate amount of distortion as well. The 12-35 lens exhibits a noticeable amount of distortion at 12mm as well. The 20/1.7 is measured with much lower distortion and I can confirm that I see no distortion when using this lens in video mode or photo raw mode. ephotozine measured a distortion of 0.543% at 12mm for the Panasonic zoom and 1.12% for the Olympus prime. So the distortion of the zoom should be exactly half, but with my copy it wasn't. I checked for firmware updates for the zoom but could not find any. My copy had the shiny finish with the ugly purple cast. I don't know how ephotozine and other reviewers measure distortion, maybe this kind of variation is normal. The 12mm Oly was tested on a G3, the 12-35 Pana was tested on a GF3. Maybe the GH2 has different correction algorithms than the other two cameras. What matters to me is that on the camera I use I could see no noticeable improvement in 12mm distortion, so I decided for the Olympus prime since it is cheaper and faster. For other users the 12-35 zoom with 2.8 might be a perfect allround lens. It all depends on what one needs.
  • @kodakmoment
    I suggest to make more formal tests. Including RAW and JPEG. It is very strange that they have any noticeable distortion (as ti must be software corrected).
    May be they have some bug in lens firmware.
  • I am shooting raw and the software I use is apple aperture which I think is autocorrecting the distortion since it does on the 20/1.7. And doesn't the video mode auto correct distortion, too? I could see the same low but noticeable amount of distortion there. Straight lines at the edges of frames distort about equally with both lenses at medium distances of about 3 to 8 meters. At a distance of 50cm the zoom at 12mm seemed to distort even more than the olympus prime. But this is not my usual shooting scenario anyhow.
  • @kodakmoment
    Normally it must have almost zero distortion. At least in JPEG.
    If you use RAW issue can be that your software is unable to correct it.
  • I am using the GH2. The distortion is not very high for either lens, I was just hoping that the Panasonic 12-35 would be even lower. No surprise that it isn't since I am comparing a zoom with a prime lens. However I wonder how the various reviews came up with a lower distortion % for the zoom.
  • @kodakmoment
    What body are you using?
    As it looks like Olympus are unable to correct this zoom.
  • I just returned my sample of the 12-35 to the dealer. According to the reviews published after the lens announcement, distortion at 12mm was supposed to be half as much as on the Olympus 2.0/12 which I own. I am using a 12mm lens for architecture photos and video. Unfortunately the distortion of the new pana zoom turned out to be quite similar to the olympus. The Olympus gives me one more stop of light, lower vignetting and a much higher edge resolution. For outdoor run and gun shooting I already have the cheap 14-42 lens which resolutions wise is good enough for video. For indoor shooting f 2.8 is often not enough. Hence I decided to return the 12-35. I can confirm that the lens is regulated electronically. Whether the lens is parfocal or not I am not sure, but since it is not possible to make a smooth zoom with constant illumination while filming it does not matter anyhow since there are autofocus and focus expansion if needed. If Panasonic had considered to build a f 2.0 lens with a slightly larger long end, for example 50mm, at a higher prize and at the size of the 14-140mm lens, I would have kept the lens. Panasonic's mft sensors are just not light sensitive enough for 2.8 zooms.
  • @stonebat "Can you please take a sample video and share it?"
    Unfortunately I can't. I reinstalled my Win 7 not a long time ago and I still haven't installed a software that converts video files for YouTube. I'm too busy on my main work to finally do it at home :-)
    @bkmcwd, could you upload such a test clip (showing the zooming in/out glitch with brightness), since you do have the same lens?
    @stonebat, anyway, knowing that this lens has this brightness glitch, especially when zooming out slowly, this glitch is much smaller than a glitch with any panasonic lens that (officially :-)) has a non-constant aperture.
  • @Stonebat Yeah it's a very nice lens, but I think for the price I would get a Nokton first.
    @christianhubbard Sorry about that I uploaded them and fell asleep on th couch before switching them to 1080p, they are 1080p now.
  • @mee Its so hard to judge the lens if you only upload a 720p file
  • @mee OIS is nice to have, but it can't replace a rig for sure. At 12mm, it sure looks rectilinear. Some like rectilinear at 12mm or hate. I don't like a medium shot at 12mm rectilinear for sure. It distorts the face toward corner. A long shot would be fine.
    My impression is that this lens is an excellent zoom lens. But not a prime killer. I'm just glad that it's finally out so that I don't hear about the rumors.
  • I actually got to mount this lens on my GH2 the other day, but the shots are just from inside the camera shop, and not exactly my most cinematic work. The lens felt good in the hand, and compared to most panny lenses the focus ring felt good, but I tested the Nokton 25mm F.095 lens this day ( I know it's apples and oranges ), and I am finding it harder and harder to enjoy panny focus rings even on the nicer lenses. Focus seemed smooth but I had a bit of trouble dialing it in.. granted it was my first try, and I am not exactly the most experienced focus puller. Also despite knowing better I kept trying to adjust the aperture X D
  • Zoom shot is still being used. Doug Liman's The Bourne films series used fast zooming. Also it's not so rare to see dolly zoom shot and tracking zoom shot.
    As @LPowell pointed out, electronic iris control sucks.
    @MikhailK Can you please take a sample video and share it?
  • @gameb As I said earlier, it's parfocal. At least, I think so. Correct me if I'm wrong :-)
    You can test any zoom lens by zooming in to the max FL, Shift the lens's AF to M or manual, take a picture. Then pull out the zoom at the widest FL, also at widest aperture, take the picture. Go to your PC or MAC and download the images. If your image is in focus at the max FL as well as it's widest FL, then your lens is parfocal.
  • @MikhailK: "I saw no motion picture made with primes only!" Sorry, MikhailK, but I think it is the other way round: zooming was and is very rarely used in cinematograhic films, a part from the italians (especially in the 60s and 70s), a lot of asian productions or other rather cheap productions: Primes is what you normally use in cinema.
    I am really looking forward to work with this lens. Like everything, it depends on the way you use things. But I still don't have it really clear, is this lens parfocal or not? It is important to know even if you don't zoom. If it is parfocal, why does Panasonic not mention it?
  • @nomad, @gameb, In general I agree with you that this lens is one of the best supersharp primes for MFT. And I don't zoom everytime I shoot something. And I agree that having different focal lengths in one handy case is a must. But sometimes there are situations when (suddenly) you realize you gotta make this shot with zooming in or out. It all depends on the artistic way you wanna have your picture made. Any way, I saw no motion picture made with primes only! Also, when I shoot my child (she's 2,5 years old) who can't "hold still" at all, zooming in/out helps me a lot in some cases.
  • Seconded. If, as a filmmaker, you regard a zoom more like having different focal lengths in one handy case (instead of really zooming too much while filming), it should still be a great lens. The image characteristics look much better than most of the supersharp primes for MFT.
  • In bkmcwd post on page 2 (his friends video), there are a few zooms in there, they look fine to me, a part from, as I said I don't like zooming too much. I can understand what the issue is you are telling us, MikhailK, but may be its not so dramatic as to say, its not a good lens for videographer...
  • This article doesn't say anything about the glitch we discussed.
    I do realize that this lens is "probably" one of the best wide-angle zoom for photographers. But for videographers it's not for sure...
  • In the old days aperture compensation was done by hardware (mechanics).
    My wonderful Rokkor 35-70mm does it smooth, silent and without a glitch…
  • What's worse is that since the camera is unable to track continuous zooming in real time, dynamic iris adjustments often lag behind the zoom.
    I think this guys need to work on firmware.
    It is not rocket science, especially comparing to their AF performance.
