Hi people,
Just want to share this film though it's all thanks to Driftwood and Vitaly I wanted to create this film and show everyone the sharpness and quality you can get from this little camera. It's also an experiment to see how hard you can go on the grading even though the codec isn't really made for that kind of stuff. It worked pretty good, better than I thought actually even though we all know it's not perfect in some way. But still, it's very cheap equipment and compared to many other cameras with the same prices it's really good!
I was using the old Orion v4b, Nostalgic (-2-2-2-2). I can't say I recommend Nostalgic though I had a hard time to get the skin tones back, it seemed to often get blown out while the rest of the scene could be really dark.
The lens was Samyang 35mm 1.4
                  @davidhjlindberg Nice work! How did you do the slo-mo part with her hair flowing like it was shot with 1000fps?
@davidhjlindberg What adapter for the samyang did you use?
I've been trying "Globular" Cluster V5 last night, image quality is awesome and bitrate is less crazy than Sedna AQ1. However I have random issues reading the video within camera. At first everything was fine. Then "Unable to read the video file" message was displayed on the LCD (affecting both video and stills !) I am using 16 Go Sandisk SD HC Card Class 10 (30Mo/sec) When camera is switched off and on the video can be played.
Does someone have information to share on this problem? Thanks
PS : I may try the new Cluster V5.1 (Sedna Based) but it seems "beta"
One battery-removing lockup 7 seconds in with Cluster v6 RC 2. Static scene, HBR mode, Smooth -2-2-2-2, manual lens, SanDisk 64GB 95MB/s. Was not able to reproduce issue in subsequent attempts. Image quality is some of the best I've seen using HBR mode.
@driftwood, thank you
@disastronaut use conversation pm only please! See the group you were added to ? :-)
@davidhjlindberg Simply brilliant. Well done David.
@davidhjlindberg Been waiting on this for some time now Bro LOve your Work
@davidhjlindberg, amazing piece there! Love it. This's another solid piece made with that GH2 that I have seen so far. Great work! Keep up the good work.
@davidhjlindberg :color grading is amazing!!!...love your work
@GhostLayer This happens periodically with several of the hacked settings, not just with Cluster. Normally I workaround it by turning the camera off and again like you did. As to when it happens, it seems to be related to how you review and shoot your footage. I seem to remember that if I switched modes too quickly it could sometimes do that, or if I rushed the camera after I finished recording.... but it was never enough of a nuisance for me to try to properly debug it. That would have meant taking time away from all the other testing. :)
I just lost half-day worth of video on my SDXC card. First time such thing happened, so far, in a couple of years using all kinds of devices/SD cards...
Video was shot on GH2 with Cluster v4. (at this point I don't think the hack has anything to do with the problem, though...)
I then used a card reader to transfer files from some CF card. Reader has SDXC/SDHC slot, so while CF files were transferring, I put my SDXC 64GB 95MB/s card in it as well, and it opened fine. I then tried to rename a dozen video files (by teh way guys, Cluster v4 seems to span just fine in 24H mode.)
While file rename operation was in progress, it took longer than it should and ended in Win 7 error message, something about wrong drive inserted.
Sure enough, SDXC card disconnected.
Subsequent attempts to read it (in a number of different readers) revealed that the entire file structure is gone, and Win wanted to Format the card because it only saw "RAW" data on it.
My attempts to recover the data (I have Recuva app, it works OK most of the time) were unsuccessful.
So looks like the entire bunch of videos on this card is lost.
I think, most likely, either the reader hardware, or Win OS glitched and bricked the card's file system.
So I suppose, when it's time to transfer footage to your computer, don't try to operate on more than ONE card at a time...
I needed OS to write to the card as I was renaming files there. I routinely rename files on card before transfer, for years, and nothing of the sorts ever happened. Suspicious mostly of the USB3 card reader I have - it probably glitched, disconnected the card during renaming, and voila - it was equal to pulling the card out without dismounting it properly, so the file system was lost!
I would never write anything to my originals!
– The first thing I do when I get the card out of the cam is protecting it.
– The second step is backing it up.
I even refuse to let anyone check images on the card – maybe I'm paranoid, but I never lost a single file that way.
I rate my work and that of all other participants in a shoot more valuable than having a few extra cards at hand.
Nevertheless, I feel sorry for your loss.
@thepalalias thanks for your answer. I have definitely rushed on the play button :) I'll try to wait a few seconds to see if the hurry causes the glitch.
@mo7ies I was using Twixtor, and those scenes were shot in 720p 60fps. @disneytoy I don't really have a rig, just my GH2 set on a tripod. On the handheld shots I was just holding the legs of the tripod.
Thanks everybody for such a nice appreciation!
