@LongJohnSilver You might want to check your lens adaptor. The screws that hold the lens mount sometimes get loose making the lens shift slightly making you out of focus. It's happened to me on a shoot. best LukeV
@ LukeV thanks for the suggestion. I checked yesterday and it's ok. Still not convinced of the sickening results I shot some clips with the same Sedna settings just switching to 24p cinema mode and they are perfect as usual. Nick gave a look at my mts and it seems I stressed too much the current HBR implementation going 80+Mb with that scenario. BTW reviewing my notes (I accustomed to write down lens/camera settings for every shot) I realized that the clip I posted on Vimeo is shot with the razor sharp Lumix 20mm at F8. So the HBR could not cope with the amazing number of details in the scenario. @driftwood was quite more technical explaining it :)
Bye
@LongJohnSilver Good to know. I've been eyeing the 20mm. Thanks LukeV
few frames grabs from sedna aq1 footage I shot . a bit of background info on gear used, I added here : http://www.personal-view.com/talks/discussion/426/gh2-stalin-samples-topic/p6
@peternap What is M6?
@strancali No, I wouldn't. That's a hard question to answer and if I had the answer, I wouldn't still be testing.
A lot depends on what you need/want. If it's the most stable, reliable setting with very good image quality...I'd say Sanity 5. If it's the very best image quality with less stability, Mysteron. If it's stable with very good Image quality and low light, Cluster.
Depending on testing, Flow Motion 2 is looking good.
That's just my opinion though and there will be a lot of disagreement.
@peternap yes I know what you mean. It's a tough thing since are so many flavors to choose from and I for one appreciate everyone's efforts. I'm trying to find the best solution for slo mo work and since 720p has 60fps, it's easier to make it look good with twixtor I guess?? I will try out Mysteron again in 720p and see how it goes.
@peternap Does that mean shutter 1/4000?
@thepalalias No....I shouldn't be trying to do 2 things at once. I can't think straight when I'm only doing one. 1/2000
With twixtor you better use a Intraframe setting.
i have M6 stable with 720 pal with gop 1 intraframe, ntsc sadly not, so it is in gop2. "not released yet".
But Driftwood have some very good settings for 720...
this one i did with Driftwood GOP1 AQ2 'AQUAMOTION' Experimental patch.
No skater to a blue clean sky, but with sand what gets around, thats a big problem for twixtor
@hakosuka Sedna is consistently better than Quantum V9b for 24H - my testing was enequivocal on that subject. I did not perform similar testing for 720P between the two.
@hakosuka Sedna is consistently better than Quantum V9b for 24H - my testing was unequivocal on that subject. I did not perform similar testing for 720P between the two.
That's again, a matter of opinion. Sanity is a vastly improved version of the OEM Firmware. Driftwood's patches are a whole new breed. I guess if I had to pick one it would be Mysteron...until a new one comes out. You have to remember that high performance 1080 24 and 720 60 don't play well together.
