Successfully patched my Japanese GH2 using PTool 3.61d through Wine on Mac, how nice to finally have English menus! Will post footage with the recommended settings tomorrow. Outstanding work Vitaliy!
Does anyone know of any other stream-analyzers though? Streamparser will not work with Winebottler because of a bug with NET Framework 4 or something...
FWIW - Hacked SH footage using suggested settings would not play well on Panasonic Viera HDTV. Occasional video slowdown and stuttering audio. Same footage plays fine on MacBook Pro where video and audio quality was excellent.
FH 35Mbits No Crashes. FSH 42Mbits Recommended Settings Crash if heavy scene detail and or Motion. Cannot Write To card. 24H No problems at 42Mbits it wont crash yet. Seems to be solid. However get some weird artifacts. "Some objects on the scene seem to be dancing in place independent of where they should be statically located."
I will however reduce to 3x Mbits on all modes until I can get a faster card that wont hang.
Only way to wake up from crash is to take battery out.
Thank you Vitaliy, I donated months ago but will again. :D
Mr. V. just to clarify . . . 3.61d has "end user" friendly, stable settings, correct? (Along with, of course, properly labeled and easily avoided "tester" settings.) Also, is there a topic dedicated to the finer points of running PTools on Macintosh? I looked around but didn't see one.
I tried FSH: 36 Mbit FH: 24 Mbit and 24H: 36 Mbit 24L:24 Mbit for me only these values are enough stable for my SD cards works great on: SanDisk class10 Extreme 30mb/s 16GB and Transcend class 6 32 GB ... No crashes, tried 40Mbit there was crashes on intense scenes ... (faster SD cards might work ...) Not much saturation at 36 Mbit, much better than 17 Mbit at 1080/50i ...
Thank you VK
File: F:\PRIVATE\AVCHD\BDMV\STREAM\00000.MTS Size = 366 938 112 Bytes (1 911 136 Packets) Stream: Max Speed = 38 614 520 bps Mode = 1080/50i PCR Timing Interval = 0,095 seconds Clip Time = 0:01:17,32 Average Total Bitrate = 37 965 660 Average Video Bitrate = 36 805 478 Average Audio Bitrate = 235 072 Average Other Bitrate = 925 109 Max GOP Size = 2 686 080 Bytes (21 488 640 bits) Video Frame Size (Min/Ave/Max)= 37 248 / 187 875 / 408 960
Raw footage shot with the GH2 and Ptools 3.61d using Vitaliy's recommended settings for 1080 24p. End user settings only.
Footage was shot against a plasma plate to provide a lot of action in the footage to ensure the bitrate was high. Bitrate shits out for the first few frames. Not a big deal.
SD Card is a 16GB Transcend Class 10
Vimeo Login to download RAW footage.
Youtube
File: E:\temp\Hacked Panasonic GH2 1080 24p PTools 3.61d 42mbps Recommended Base Settings.MTS Size = 174,526,464 Bytes (908,992 Packets) Stream: Max Speed = 45,275,110 bps Mode = 1080/24pN PCR Timing Interval = 0.095 seconds Clip Time = 0:00:31.57 Average Total Bitrate = 44,222,143 Average Video Bitrate = 42,703,063 Average Audio Bitrate = 470,168 Average Other Bitrate = 1,048,911 Max GOP Size = 3,092,928 Bytes (24,743,424 bits) Video Frame Size (Min/Ave/Max)= 25,728 / 227,184 / 772,416
Stupid mistake. Missing a "0" at the end of FSH/SH bitrate. You'd think I'd know better by now. I looked at it a hundred times then finally figured out.
About 1st sec hic-ups. It's always a good practice to run about 5 seconds of pre-roll anyways (maybe more maybe less). Anyone who works with video typically does that already , so unless Bigfoot suddenly pops out and charges you from the woods....it doesn't really matter.
