3. Remember that new encoder patches are for testers. Use simple bitrate patches.
4. How can I make encoder hold better in low detailed scenes? Try tweaking bottom limit in AVCHD encoder. Use Patches for testers->AVCHD Encoder->Bitrate Settings and choose proper bottom setting patch. Remember that original bitrate patch already adjust this for you, but keeps bottom value conservative (less than 70% of bitrate setting). You can override this if you wish.
5. How to update firmware: a. Load GH2 1.0E firmware, see 1. how to get it. b. Check all necessary patches, Version increment must be always checked. c. Save firmware. Just change last digit to any number you want. d. Copy firmware to root of SD card. Fully charge you battery. Do not even attempt to use AC coupler! e. Power off your camera if it was on. f. Power on camera. After this press (not hold) green play button. g. You'll see hourglass and prompt to update. h. Press down arrow and after this Menu/set. i. Wait until upgrade will be completed.
6. How to privide reports in this topic? a. Use systematic approach (one-two changes at a time with careful thinking). b. Shift-Click on round button in PTool to save your particular settings. c. Paste here settings with detailed observation + MediaInfo screenshot + StreamAnalizer screenshot.
7. If anyone wants to share uncompressed video - you can use http://www.sendoid.com/ to instantly share very large files (download their Adobe Air client that work on any platform). Of course you need good connection as it uses p2p tech.
