CS6 Production Premium applications:
Speedgrade CS6
An optimized Mercury Playback Engine that is faster than before in software-only mode, and also sports a broader range of choices in graphics cards.
After Effects part
Links:
http://success.adobe.com/en/na/programs/events/1203_16108_nab.html
http://success.adobe.com/assets/en/downloads/guides/PL_CS6_WN_Reveal.pdf
http://success.adobe.com/assets/en/downloads/guides/SG_CS6_Intro_Reveal.pdf
http://blogs.adobe.com/premiereprotraining/
http://blogs.adobe.com/toddkopriva/
http://blogs.adobe.com/insidesound/
Trials:
http://www.adobe.com/cfusion/tdrc/index.cfm?product=production_premium&loc=en_us&sdid=JUJDJ&virid=adbe2012-JUJDJ
http://www.adobe.com/downloads/
Buy:
Good God....
Yess! :)
Wait a minute, I'm using AE CS 5.5 and it's got Warp Stabilizer already!
(edit) @sohus I believe the novelty is Warp Stabilizer on PP, not on AE.
ok nice, some more info about the new raytraced engine in AE6 would be nice :)
oh yes
I'm very interested in Prelude and the improved multicam for now. Former possibly addresses my primary need, proper management of videos. Not just adding tags to files, but to sections of a file. And the multicam was in need of improvement. Personally I could live with the limitation of four cameras, but stability and auto-sync (actually in general) are welcome. Warp stabilizer in PP is nice too. The other improvements are nice too, but I still have to get used to those tools first. AE is just some basic stuff and audio is the thing I'd like to improve at in the upcoming months. Especially since Audition seems to be such a nice application.
@albertdros, check this one out: http://www.motionworks.com.au/after-effects-cs6-3d-material-template/
Hey Guys i know it's probably not the right place to ask that but i need a hand I m getting crazy here, i have been trying to open a premiere pro CS 5.5 sequence of a short that i m working on, in after effects to be able to do color correction in AE...I wanted to open the Premiere sequence, this way i wouldn t convert and degrade anything and would use the mts files directly...I opened the project everything seemed fine at first...I graded it...rendered to queue, rendered it but now EVERY TRANSITION/DISSOLVE DONE IN PREMIERE PRO, every text, even the sound mix disappeared after render...It s like it just kept the basic cuts...WTF is happening...i lost a whole day of work on that...Can someone please help me???
there's a free series of tutorials covering AECS6 new features at http://www.video2brain.com/en/products-313.htm njoy:]
@AlexManta I am not sure what the problem is but you have an autosave folder with previous versions, if neccessary.
So with AE's native support for Adobe SpeedGrade .Look files, does that mean I can import a Speedgrade project into AE without rendering?
My workflow would then be: Premiere (edits) => Speedgrade (Tech, Creative Grading) => After Effects (Effects, Neat Noise reduction, etc)
I like the improvements! Any Word on availability? And will plural eyes still be needed?
Edit: seemes like date is not announced yet
@AlexManta cross dissolve should work in cs5.5, it was a bug in cs5. This is the list of stuff that transfers across: http://help.adobe.com/en_US/aftereffects/cs/using/WSbaf9cd7d26a2eabf53ab041041081290f-7fbb.html#WS3189FAE2-6A10-4144-B337-8FF81B2E6C8C
@evero - I've been wondering the same thing; when is this available? I'm glad Adobe is more transparent than ever with previews, but why not give us a date too?
In PDFs it is stated as Q2 2012
This might make me come back to Premiere Pro, which I abandoned when I needed to do multicamera edits using more than 4 cameras. Last time I used PP was version 2, and then I abandoned it for Sony Vegas, which is proving very unstable on my PC. This new CS6 software looks the business!!
@AlexManta You've hit one of Adobe's awkward gotcha's in Premiere/After Effects integration. While the link provided by @tuprware documents the gaps in detail, the rule of thumb is that AE is oblivious to all Premiere transitions other than cross fades. Adobe also claims that video effects that are built into both Premiere and AE will be preserved, but I personally haven't had the time to do the detailed individual tests to verify this.
I too, prefer to use AE to color correct Premiere projects (since Premiere is not color managed). Here's the workflow I use in order to maintain sanity:
Assemble all clips with in and out markers in Premiere, and generate timelines with the appropriate defaut transition (cut or cross dissolve). Apply manual cross dissolve or cut transitions as needed. Normalize the stereo audio levels in each clip.
When done with all editing, make a new Master Sequence of the same type, then drag all other sequences into the Master Sequence.
Unlink the Master Sequence audio track and send it to Adobe Audition. Use Audition to EQ, normalize, compress it, and convert it to 16-bit 48k if necessary.
Open the Premiere project in AE and verify that all edits and transitions remain intact. Use the Master Sequence to grade and apply video effects to the entire project. Use the original sequences to grade and apply video effects to individual clips.
Render the Master Sequence in AE to an appropriate intermediate format, with enough bit depth and bitrate to avoid visible degradation in all target distribution formats.
Import the rendered intermediate file back into the Premiere project and create a Sequence for it. Then add titles, soundtrack, and a separate surround sound mix if desired (using the original audio tracks).
Render the imported sequence to each target distribution format in Premiere, using multi-pass encoding when available. This will produce optimal video quality at low bitrates.
Support for more than four cams, nice plus. I think for me I would hope to see a tweaked H264 renderer that squeezes a few drops more IQ out of the source files. We will see.
@DrDave I use the MainConcept Codec Suite 5.1 plugin for Premiere Pro to tweak H.264 and MPEG2 renders. While it's not cheap to license, it provides access to virtually all internal encoder parameters. It also includes an optional Dolby Digital 5.1 pro encoder for DVD and Blu-ray renders. Here's a link to the MainConcept website:
http://www.mainconcept.com/products/apps-plug-ins/plug-ins-for-adobe/codec-suite.html
Most excellent. Nice to put WS and RSR in PPro! I like the optimizations in software-only mode. No brainer upgrade now for the suite. Speedgrade looks awesome!
Komrades from compression.ru at: http://compression.ru/video/codec_comparison/h264_2010/ made a humongous H.264 codec shootout and x264 came out definitely on top where it regards to IQ: http://compression.ru/video/codec_comparison/h264_2010/msu_mpeg4_avc_h264_codec_comparison_2010_short.pdf
Mainconcept was the distinct second better. There is a balance in IQ/encoding time between both of these, however I seem to recall that the latest versions of MainConcept are heavily GPU accelerated... (indeed they are!) http://www.mainconcept.com/fileadmin/user_upload/download/product_sheets/ATI_Speed_Results.pdf )
Choose your poison. ;)
@duartix The major workflow benefit of the MainConcept Codec Suite plugin is that it is seamlessly integrated into Premiere Pro. To use x264, I believe I'd have to make an additional render from Premiere to an intermediate format, and then use x264 to do a command line render. The MainConcept plugin also provides integrated MPEG2 and Dolby Digital 5.1 encoders.
