im borrowing a gh2 and fs-100 for a project where i need a stabilizer that can handle the individual weight of both cams. will be using a longer zeiss lense so gh2 set up is a bit heavier than the typical stock setup. should i get a lighter rig for them (hd2ooo) or something like the hd4ooo? the gh2 config weighs in @ 3.5lbs (lens + base plate w/camera). anyone used the hd4000 extensively with smaller dslrs? if so, please share your experiences. thanks
I use the 4000 Pro (traded from the 2000 Pro) and I really need the extra weight threshold. However that's because I use heavy lenses (Lomo cine primes) and want to use my camera on a rig on it, which makes it heavier.
I don't have a vest, but an arm-brace, which is a REAL life-saver, the improvement from just holding it in your hand is BIG and while it's not a vest, it makes it way smoother.
I have HD4000 and HD1000 as well... HD4000 is overkill for DSLR
BTW, forget about these merlin type stabilizers for serious usage with FS100.. I wouldn't use them even with DSLR's.. you can't controll these stabilizers as much as one would like to... just my 2 cents
@aprioir thanks for the comments. i think i might try the unit you mention.
I haven't used the Glidecam HD4000, but it has a payload of 4-10 lbs, which may be problematic with the GH2. I've read that the HD1000 is a better fit for the GH2 than the HD4000. You might look into the Camera Motion Research Blackbird stabilizer, which supports between 1-8 pounds and gets great reviews. The Blackbird would likely provide support for all of your cameras without any performance trade-offs, whereas the HD4000 may be less than ideal for the GH2 (though adding a cage could help).
Blackbird kits retail for $675, but I just won a barely used model on eBay for $400. The stabilizer can also be purchased without the kit for $470. My kit's still en route, so I can't give my own impressions yet. http://www.bhphotovideo.com/c/product/684655-REG/Camera_Motion_Research_2050A_Blackbird_Camera_Stabilizer_Kit.html
