I think the time mode is not accounting for the full bit rate from the I,P, and B frames. The settings I am using appear to allocate much more bandwidth to the I and P frames than it does to the B frames which appears to be the only thing displayed in the time mode.
You can check the file sizes for the exact same scene recorded with 24p and 720p. The 720p files are much larger and have MUCH less compression artifacts despite their large GOP(30 vs. 12). Those bits have to be going somewhere.
The max bit rate reported by stream parser is just a number. Look at the average bit rate value and the file size and you will see that the average bit rate far exceeds the value stated for max bit rate for Stream Parser. Stream Parser is just not giving the correct value for max bit rate. The average bit rate is accurate though.
@EOSHD Are you able to record the HDMI information from your camera? (HDMI intensity-Ninja? 6-Pack of beer given to video guy at local shop that has Ninja?) In an attempt to discover if the HDMI output has the same issues as previously noticed?)
When recording with GH2's LCD closed and EVF active, with HDMI monitor connected, AVCHD is recorded without crashing and it can playback in-camera, but results are the familiar garble and bitrate is low despite settings changed to allow higher bitrates in PTools.
For comparison here is Sony HX9v 1080/50p AVCHD analysis (PS mode 28Mbit), though StreamParser does not recognise some information it seems :)
Stream: Max Speed = Unknown Mode = 1080/50pN PCR Timing Interval = 0.090 seconds Clip Time = 0:00:12.96 Average Total Bitrate = 26,214,399 Average Video Bitrate = 25,178,538 Average Audio Bitrate = 282,000 Average Other Bitrate = 753,861 Max GOP Size = 0 Bytes (0 bits) Video Frame Size (Min/Ave/Max)= 268,435,455 / 0 / 0
Although StreamParser is not labelling frames or GOP, I am speculating it has much higher bitrate i-frames than the GH2 footage looking at the chart.
More tests... Pulling HDMI cord out during recording deactivates clip recording. Then when I hit record again without HDMI connection corrupt image and battery pull is required. So when HDMI monitor is connected and turned on, it does seem to override the PTools settings for 1080i -> 1080p in case of live view on both screens and put camera back in interlaced mode, apart from encoder. When not connected, encoder settings seem also to effect live view output during recording.
HDMI mode was 1080/i, and image was fine on both LCD and SmallHD whilst recording.
It appears as if without HDMI monitor connected the GH2's LCD shows encoded footage (garbled) whilst with HDMI connected it is a different 1080/i feed that is shown on both screens, whilst AVCHD encoder gets the garbled information as normal.
Until now I got the Memory Card error every time attempting 1080/50p, various settings tried, corruption in live view when record button activated - but then I plugged in a HDMI monitor (SmallHD DP6), hit record and the GH2 entered record mode fine, both the HDMI output and live view did not have the corruption of before, but unfortunately the AVCHD file recorded was corrupt with the half pixilation and half heavy macro blocking, weird corruption, etc. others have also reported.
Here is analysis of my corrupt 1080/50p MTS file. Bitrate seems far too low to support 60p, so need to change that.
Stream: Max Speed = 18,382,980 bps Mode = 1080/50pN PCR Timing Interval = 0.095 seconds Clip Time = 0:00:11.54 Average Total Bitrate = 11,402,070 Average Video Bitrate = 10,759,986 Average Audio Bitrate = 235,896 Average Other Bitrate = 406,189 Max GOP Size = 1,165,248 Bytes (9,321,984 bits) Video Frame Size (Min/Ave/Max)= 7,680 / 27,445 / 373,440
Notice size of first few frames in attached StreamParser GIF!
Has anyone had a play around with the "1080 progressive" or "1080i59,97 --> 59,97p" patches yet?
First time you use them it freezes the camera, giving the "Memory card is too slow" message. But if you eject the battery and bootup again you can record just fine. Problem is that the video output is all garbled, top half of the frame is very pixelated and the bottom half has massive corruption with bright colours flashing all over the place and large horizontal bars of green and magenta scrolling upwards. Any ideas?
Thanks :) I'll upload a downloadable clip on vimeo in a little bit. Still, to get over the motion recording issue, after everytime the camera is powered down, I need to record in 24H, then switch to SH and I have no problems with any errors.
Yes it can glitch. In fact if you look at deprecated topic you linked I started whole thing about problems. But I think that talking about glitches in current context do not have any value.
