I think they are already present in FAQ for now.
I pretty much just use the FHD for almost everything, and only switch over to SH mode if I am going to be using it for slow motion. The higher framerate (60fps) of the SH mode, combined with a lot of movement is probably why the camera crashed. It also depends on what f stop you are using, if you are at say f11, or f16, that can cause problems since there is so much detail. But if you go to a wider f4 or f5.6, you have less things in focus and the camera can handle that better.
Hope this helps,
Michael "Pixelphile"
