Here (Alibaba express shop, shipping directly from manufacturer):
Around $80-85 shipped.
My review:
From hardware standpoint long time ago it was good cheap LCD screen for movie makers.
Processor : MST719DU-LF LCD : CLAA102NA0ACW (1024x600 resolution, LED backlight) Battery : 7.4V 2300mAh
Two speakers and headphone output (with good metal socket) to check sound. I don't go to tuner, USB input, SD card player, etc as it is not very important here. To be short, you can check your JPEG files just by inserting SDHC card. But you better not to.
Image quality:
Average for portable devices. I like the colors (only for specific LCD panel used, later ones seems to be worse). Unit has ability to set color temperature (four presets, not VGA it is adjustable very precise) and many other parameters for HDMI input. Menu can be set to be almost transparent and position can be adjusted.
From software standpoint it is not all good. First. HDMI connection must be slightly improved by manufacturer. I suggest to set HDMI format to 720p60 in GH1 menus (as this works fine most of the time). Sometimes GH1 go to 2-10s cycle trying to establish HDMI connection (turn modes wheel to go out of this and try again) on 1080i or auto modes. Same happens with my HD cameras. After all screen flashes it starts to work fine. Second and most important. Unit has small overscan. So, framing is slightly off and also sharpness is not perfect (but ok for focusing). Using VGA it don't have any overscan, so it is firmware related HDMI only thing.
My unit is mounted on telescoping arm.
I really suggest to check much better monitors at
http://www.personal-view.com/talks/discussion/717/special-deals-lighting-fresnels-evfs-monitors
We have one on deals from time to time, with peaking and 1024x600 res. I'll add it to monitors deal topic tomorrow.
I'm also looking for a better monitor for getting better focus on my GH2. Would you recommend a 7"? Looking at this one since it has peaking. http://www.aliexpress.com/store/product/2012-Best-Seller-7-hdmi-monitor-for-Camera-5D-II-7D/808853_509047849.html
Need hdmi or vga for the teleprompter. That might not be a deal breaker since I think the software we use can flop it. Thanks.
I think that they do not have it.
I really suggest to visit pandawill.com and get good modern Android tablet instead. Unless you need hdmi input.
I was thinking of buying the Leadstar 10" to replace our broken teleprompter. It seems to have the 1/4" mount we need. Wondering if it has a way to rotate the screen in the menu?
You checked my message directly above, right?
I alreayd told that this guys had bad habit of changing panels.
I think people realize that you can't get a completely accurate view except on a calibrated monitor. But people are saying it's not even close. Some of the Marshall monitors that I have, while not 100% accurate, are pretty darn close and can be relied on. It sounds like that is not the case with this monitor.
Yep, it is not recommended as it had been in a time. Plus they constantly changed used LCD panels. So, first ones had normal color and not a bad screen.
+1 It has a very bad screen, awful colours, I sold it....
I bought this, and I don't think it's worth it. The framing is off by a lot, and although it is 1024x600, the picture seems pretty soft, so it doesn't help much with focusing. Better than nothing, but I wish I had spent about $300 on something with peaking.
