mpgxsvcd 7:00AM ReportAwesome
I am going to try to do the bit rate tests tonight with the test charts on a tripod. I have a spreadsheet setup to keep track of every change. I will change one parameter at a time. Hopefully I can post some files tomorrow. I just did a quick test with half of the original GOP and bit rate set at 40 mb/sec for each resolution. The first 2 seconds of a tree blowing in the wind showed almost no compression artifacts just like the GH13. Then you can actually see the macro blocking suddenly start after 2 seconds. If we can get the whole video to look like the first 2 seconds everyone will be VERY HAPPY.
