@cbrandin - "All this patch is doing is to force the codec into fall-back mode."
Thanks for coining a descriptive term for this AVCHD encoder syndrome - Fall-Back Mode. With GH2 patch tweaking, I've seen these dysfunctional patterns occur far more often than outright recording failures. I saw Fall-Back Mode happen less often on the GH1 - it would simply break under stress. The drawback, however, is that Fall-Back Mode is usually difficult to spot in test footage without the use of tools such as Stream Parser. Reliability testing on the GH2 has required far more time than it did on the GH1.
@cbrandin "people become discouraged because of the low quality of these patches"
Well said,
that's what sharppixels trying to do, I'm sure. He's trolling. He popped up a couple of days ago. His arrogance, to first time post with the world's best patch is antagonizing.
Which I'm sure is what he's trying to do.
He's creating noise and confusing newer people who are trying to get real info and help. Works for canon or sony maybe?
All this patch is doing is to force the codec into fall-back mode. The Panasonic codec has a mode it goes into when it fails. Resolution is cut back to SD equivalent. All this patch is doing is failing after 20, or so, frames. You can see it where the frame size drops to 300K - which is much lower quality that the factory (un-hacked) settings. Also, the P frames aren't helping because they are the same size as the I frames - you might as well stick to GOP1.
Perhaps some people will like the "look" provided by the camera when it fails (soft, low resolution). But don't kid yourself - this patch forces the camera to do what it does to avoid locking up, which is to force it into low-resolution mode. If the GH2 didn't have this safety-valve mode of operation, this patch would lock-up the camera almost instantly.
There is a lot of good information in various threads here about how to build good patches. Please do a little more reading before posting patches, lest people become discouraged because of the low quality of these patches.
it works, no doubt about that. but 1080 24p, just 7 sec. then write error. if i shoot first in 720p, and then again 24p, it works for more seconds. i did try it for a moment, no deep test... i am new with this hacking, so, no experience here.
I wonder whether for the 40-80Mb range if it's better to use a long or short GOP for low light shooting. Long GOP should make better use of the available bit rate, but a short GOP should give a cleaner rendition of the noise which will be easier to clean up. And perhaps the compression advantages of a long GOP deminish with noise in the image. I need to find the time to test this!
Sharpixels patch has not been widely tested by p-v community, and some of the more experienced/knowlegable testers here have pointed out serious flaws with some of the other stuff he has posted here recently. Probably better to stick to more reliable, well-known and extensively tested patches like Cbrandin's or Driftwood's. As Athiril pointed out, Cbrandin's 44mbps patch can also do ISO 12800; just load the patch in PTools 3.63 and then tick the high ISO unlock box before you write the new firmware.
sharpixels, i just try-id your ini file. (yes finaly i have a gh2 sins yesterday.. sadly, my card is to slow. ( 24p and handmode just for a few seconds will work. its a transcend sdhc 16gb class6
but there is something else strange. when i shot in creative film handmode. and then put the file in sony vegas, Then sony see it as follows. Streams Video: 00:00:03,337, 59,940 fps progressive, 1920x1080x12, AVC Audio: 00:00:03,353, 48.000 Hz; Stereo, Dolby AC-3
Driftwood's patch is absolutely killer, BUT, I need to shoot an event in low light (tonight) and can't afford to kill a card in 7 minutes! Love your work brother. I would like to use a 40-80M patch, but will likely go with smackmy patch since it has the iso limit removed. Would love to use Cbrandin's 44M patch, but it wont let me use high ISOs.,
