I finally got my big bad sandisk 64gb 95mb sec card. Results with quantum 7:
24p: spans without issue. plays back in camera. Tested only on highest setting. Lens 14-140 with zoom, af, ois
720p: initially this died with card write error in a few seconds on both sh and h setting. Lens same as above. Also failed with manual focus and ois off. Onr test went for a couple of minutes with the camera motionless before failing.
with 20mm lumix and af worked without issue. Did not yet test spanning.
1080i: 14-140 per above. worked without issue. Did not yet test spanning.
Thanks for the report @chauncy ... when it plays back in camera at 24p, do you have smooth audio playback as well?
@chauncy - o thats a shame well my be the Sequake is its limit. I suppose Driftwood can do most testing and tweaking with the buffers and bit rate, which should improve things
@chauncy -- got 1080/60i to playback smooth on 64gb cards, need to try 24
@chauncy was that 720p50 or 60?
@driftwood 720p 60
32GB San Disk 95mb/s - Just an update I was wrong, I left my cam rolling on a shot of some oranges, and it spanned fine on Quantum v2, it also spans on shots with movement. BUT it cuts off if there is any camera movement at all on all other Quantum patches. Stay away from the 32s if you want spanning except Q v2.
