@gameb Sure, you can change the data rate. BTW, I've done additional testing and now recommend that you set Auto Quantizer for 1080 modes to AQ4 instead of AQ3. I've been amazed at the quality I'm getting. Even 44M is very close to Quantum 5.
Can't wait for future developments on 720p60. It's the standard in my industry and I can't wait to improve the quality. I'm loving the 24p stuff but it's really going to make a difference when I can ramp the quality on 720p60.
@antticky 16GB. I tried to reproduce your problem, but can't. I shot 720 60P for 2 minutes with wild, continuous panning and had no problems. Are you shooting normal or ETC? 720 60P in ETC mode will occassionally give a write card speed error, but normal mode has been rock solid in my experience.
@magnifico Do not be afraid of the long GOP. When I developed SANITY, I tested many GOPs from short to long, and GOP 30 hit the sweet spot for 50P. It should be excellent for Twixtor. Try it.
@Ralph_B thx for advice. I am a little bit scared about 720p50 GOP Size=30 in sanity v2. Do you think that for slow motion or use of twixtor (slow motion with interpolation beetween images) plugin in premiere pro, this huge GOP won't give P or B "poor quality frames"?
may be the right place here for...an advice : Which (best) setup may I choose for my footage of skiing (i want 720p50 for slow motion pp and br max 70 Mb/s)? With a lot of motion and quick and not dirty pannings... :-) thx
My bad, i should of phrased it better. In Ptools under patches for users, I double clicked AVC movie mode, then AVC fps, then the 60-29 option is clickable. Then I clicked the txt and the warnings popped up.
