I am trying to find a post about banding where someone said they sent their GH2 back to panasonic and it came back without the banding issue. Does anyone remember this post, or who it was? I ask because I just sent mine in for some spots in the lens, and had a doh moment when I realized I should have mentioned the banding. Just want to know if it really is possible to have fixed, cause I may just send it right back when it comes back if that is the case.
Wrong sort of banding - you want this thread: http://www.personal-view.com/talks/discussion/693/gh2-showing-fixed-darker-bandstripe-20-pixels-high-across-footage/p1
I agree: having one good prime and an analog machine is the best way to learn photography. Many people underestimate photography.
Though I have just bought one myself, I hate it when I see people with their ugly digital SLR's. Most of them don't know how light works, how the sensor of their camera works, and so on. They have zero understanding of the technical aspects of photography. The reason they get 'decent' results is because digital makes it so much easier: everyone can be photographer today, all it takes is a push of a button. Let the electronics do the work for you. These people just press the button many times enough so that 5 pictures out of 100 will come out 'decent'. "I'm a photographer, fuck yeah".
Not so long ago I met some dude at a party. He had a fancy DSLR. He told me did artschool, photography. When I asked him "so do you shoot in RAW?" - He looks at me as if he misunderstood me. "or maybe RGB?" - and that guys is like, what? Turned out that guy got payed for that gig. -_-
An analog machine, forces you to be careful with what you do. You have to think out everything before you press the button. With analog you don't take as many pictures as you would with digital.
Having one 40 or 50mm prime lens forces you to move. It also learns you about the perspective of a lens. You get used to the feeling of different focal lengths. Before I became interested in photography, I just thought zooming was making the image bigger. Now I can tell you the focal length used in almost any shot in a movie by sight.
Only when you can make a decent picture with an analog cam you can call yourself a decent photographer. Otherwise, piss off with your LCD exposure cheating. Real photographers know their apertures and when to use which by hart.
PS: no offense to digital camera's; just the people who use their artificial intelligence to call themselves a photographer
I'm trying to deal with a gradient banding issue this week. If there is a lighter colored wall with shadows in my background, gradient banding becomes a problem. After lots of reading and note-taking, the few things that stand out when trying to reduce/eliminate gradient banding:
1) ETTR (seems a bit controversial to some) and darken your image in post (I use a gamma slider in CS6)
2) Introduce intentional ISO noise in camera (because it must be before quantization) and use NR in post
voila! no gradient banding. So... I've been testing this. The only thing that seems to work is to adjust the gamma until until the scene is so bright that the shadows go away. Not very useful. The in-camera dithering via higher ISO may cover the banding if you leave it in, but Denoiser II doesn't remove the noise and magically take the banding with it. I've read plenty of people blame the 8-bit situation, but I thought maybe these workarounds were going to help me. Is Neat Video the missing link here?
Attached are 3 frame grabs from PrPro CS6. As I play with different gamma settings, the banding becomes very faint, but it doesn't go away until the scene is much too bright - even brighter than what I've shown here. These frames are from Sanity X and a Voigtlander 25mm f/0.95 that I rented for a wedding this weekend.
I've also included entries from my journal taken almost exclusively from PV discussions so that future readers can save themselves some time:
-For minimal banding, you'll want to use an AQ4 patch at a high bitrate with -2 Noise Reduction (Lpowell)
-high exposure and low contrast gives you the best chance to avoid banding in dark areas.
-Banding effects are inevitably worse in dimly lit, gradually contoured areas such as an evening sky.
-And I guess that exposing to the right helps, right? Maximize your gain without clipping essential parts with Smooth -2 contrast. I also use a cooler white balance to use more of the green channel. Works out fine in CC. ( oscillian)
-a bit of noise captured in the image, and then NR in editing, will dither the 8-bit posterisation and then removing the noise gives you a nice clean image.( a more recent answer from 2013)
I have never seen banding that bad from the GH2. I think you may be experiencing a precision problem with your decoder or workflow.
GH2 = 8 bit 4:2:0 sampling. Banding is an issue with nearly all 8 bit formats and is worse with 4:2:0 sampling. This is why 10 bit was such a big deal when Digital Betacam was introduced in the 1990's. It was 10 bit 4:2:2.
4:2:0 has got nothing to do with banding.
