@Petee28 Why not shoot at great quality 60p and you can convert it to 30p in post? By converting, I dont mean "slowing" down the 60p for slow motion, but instead editing in a 60p work flow. Then after your all done, just export at 30p. (dropping the extra frames).
@Ralph_B Hey Ralph i got a quick question. I downloaded ur sanity 2 patch and found the 720p settings. My intentions of this this patch was to shoot a great quality tv commercial at at 720p//29.97fps. When i clicked the 60-29 setting, a window popped up stating the "the compression is not improved so the bitrate is dropped." I know im bastardizing the whole point of a great slow motion patch but i really need the fps to be 29.97. Should i just click the button or is their another patch that records in the format I need? Thanks
Youtube vid is very good quality. It tells alot. Vimeo is slightly bad because u (a free user) cant upload and view streaming vids in 1080p, it is only allowable for paid users. You also can not seek.
But the good thing is that u can download the original unreencoded (not encoded by vimeo) vid. :D
1080i I have it on authority from Colin at Divergent Media Support that Final Cut Pro X and FCP7 sees the transcoded files properly as upper field dominance and handles them as interlaced.
@balazer I mean the 1080i50 uses a "wrapped" mode i need non wrapped mode how do i change ? I don't want in post production to remove "extra" lines ... asked @driftwood but no answer ...
@feha, my settings do for 1080i50 whatever Aquamotion v1 does. I don't know offhand what that is. You can always mix and match settings for different modes. (with some limitations: 1080i50 is tied to 24p)
@mozes, trust us, 720p on the GH2 is very good. You won't be disappointed.
Balazer, you are right. but how can i see the quality if i dont have a gh2 i have a very cheap cam that shoots in 720p 60fps. (qmedia 145 euro) off-course the quality is :( and a canon hf100 that only shoots 25p wrapped in a 25i file, but looks very nice.....
i am looking for a other cam, i think a month off 4 now. i am sure it will for 95% the pannie gh2. And 5% something else. Its just, i cant find a good 720p 60fps file, or 50fps for download, so i can check it on my own pc....
does your patches work for 1080i 50 ? Tested it works OK but 1080i 50 is "wrapped" , i need it to record un wrapped ... So iave to go back to cbrandins 44/32
They look like 720p and they look good - as good as can be expected for the bit rates and the mix of I-frames and P-frames. Just download the different patch settings and try them out for yourself. Not having a GH2 is no excuse. ;)
Yhea me2... i still dont have a gh2. shooting in 60p is for me a must have, when its in 720p its oké, but better in 1080p. but i am happy with 720p...
i did download some clips, but those have dubble frames in it. (60p) for example, frame 5 and 6 are the same, 11 and 12, 17 and 18... etc.... this was not raw material, but edited, so it can be in the used codec..
Here is my stab at GH2 720p60. SH=44, H=33. The video recording seems reliable so far. SH spans most of the time, and H spans all of the time. The files play back in the camera. The base is Driftwood Aquamotion v1, with reliable intra 24p and 30p with spanning; 24L lowered to 66. Credit goes to Driftwood.
