Hello everyone,
It's weird: I have the impression that on my GH5 (mark 1), four of the rubberized areas on the camera are coming off! On two of these spots, there is like an air bubble where the rubber is coming off. And on another spot, it looks like the rubber has expanded : it won't stay when you push it back to its position, and comes right off again.
Has any one of you had this? What have you done to stop or solve it?
I have already seen this on an old Panasonic Lumix DMC-FZ50 (a bridge camera). In this particular case, it was obvious that the rubber had expanded: it had come off, and was obviously larger than the section of the camera it was supposed to cover...
In the case of my GH5 I was thinking of puncturing the air bubble with a needle plus syringe. And then try to inject some glue with that. For the one other last spot I was considering cutting the part of the rubber that has expanded...
What do you think? Which glue should I use for that?
Thanks a lot for your support!
P.S. I just enclosed three pictures: picture 2 is just the same spot as picture 1, just from beneath.
Hi everyone,
Any tips on what the glue (type) might be, that I get hold of the right thing, when I get to it...
Thanks a lot in advance.
