Looks like DJI is about to launch a direct competitor to the new micro wireless mics now available (like the Hollyland Lark M2).
A new DJI Mic Mini appears to have been registered.
The DJI Mic Mini is getting ready for release. Black and White editions.
There has not been a leak of a possible receiver.
A transmitter stand alone kit will work with Action 4/5, Pocket 3 and phones I would guess.
Reduced size might remove internal recording options and perhaps the noise reduction as well compared to the Mic2. Perhaps also the external mic jack.
                  Finally the Mic Mini kit with receiver and charging box.
                  The battle of the wireless mini mics
This week Røde presented their new Wirelss Micro mic and beat the new DJI Mini Mic with a few days.
A couple of differences: DJI can connect straight to your phone (as well as the Pocket 3 and Action 4/5 I would pressume) thanks to the bluetooth option which Røde has not. However if you need two mic transmitters to your phone the Røde Wireless Micro seems like a nicer option because the receiver is much slimmer and smaller.
This is mainly possible by omitting the audio out jack as well as any big buttons on the device. So the Mic 2 receiver is more versatile, but size and bulk suffers. So mainly the mics are slim with the DJI solution here.
But how long was the user in paradise? The new DJI Mic Mini charging case seems to have room also for the dead cats attached to the mic, while the slim line case for the Wireless Micro appears to have not. And the way Røde designed their Micro deadcats they take up more space as well. So sexy charging box is not so sexy after all with the additional carry on.
And the Røde Wireless Micro is a complete package as i needs the receiver regardless. But the DJI Mic Mini you can buy only the transmitter mic separately for your phone or DJI action cams.
Official info on the Røde Wireless Micro: https://rode.com/en/microphones/wireless/wireless-micro?variant_sku=WIMICROC
DJI MIc Mini has yet to be officially released.
                  Carry Less, Capture More
November 26, 2024 | 8 AM (EST)
One week to early:
Video has been removed.
                  So the Mic Mini is out and the usual influencers are out with their infomercials. I must say that the value of these is diminishing every time there is a new product release. Mustly flashy junk pieces with smoke and mirrors to sell you new junk. Oh well.
Mic Mini limitations: no internal recording, no LCD screen, no Sony hot shoe connector and no lavalier mic input on the transmitters. Also, there is no USB-C on the small transmitters, so you get a small charging base if you don't get the big kit with charging box.
Mic Mini Plus: extended range (400 meters?!), two levels of noise cancellation, lower price, lower size of said transmitter mics.
Apparently there is no x-compatibility with the Mic 2 system. You can not connect a Mic 2 receiver to the new Mini Mic transmitter i.e. Which is strange considering the Mic Mini works with the "Osmo Audio" ecosystem, like Pocket 3 and Action 5.
And as mentioned above, perhaps consider the Røde Wireless Micro if usuage with Phones is your main target.
"There is talk that when using Bluetooth, the digital sampling rate is slashed from 48k to down to only 16k. That would mean that any audio frequencies about 8k are cut off. When switching back to 2.4ghz transmission, the sampling rate jumps back to 48k. Have you heard this yet?"
Might not be sampling per se, but lover bitrate on the transmission codec. So Mic directly connected to Phone with BT which will always sound inferior to the use of the separate receiver box.
Is quite handy having this new DJI mic going straight into a S16 / 1" camera with an integrated gimbal, I'm fairly tempted to get a DJI Pocket 3 with the new DJI mic as a minimalist / affordable before I go overseas as a great portable vlogging setup.
Anybody have guesses as to if the DJI mic might even be compatible with the older DJI Pocket 2?
