Panasonic S5M2 with Phase Hybrid AF
  • 64 Replies sorted by
  • my bad. I got confused by S1H, S5MII is the cheap one, this is good news!
  • @endotoxic
    The FX35 sensor is not softwere but hardwere binned, it reads out 4 sub pixels as one. The 4 sub pixels are quad Bayer (the same color) and not RGB, and they can't be accessed se individually. For all porpoises, the FX35 has a 12 mp sensor and it was lunched at duble price as the S5.
    If you are so keen into making such comparisons disregarding the price, why don't you compere the poor 24 mp sensor with the one found on a Red Dragon, the later is looking much better in specs :).
  • @eno
    FX3 It is a 48 mpx sensor binning 4 pixels. It is 12 mpx by software.
    This shows you how far behind pana is.
    About Color and overall quality S5 is superior.
  • "NEW YEAR - NEW PHASE" teaser on Instagram.
    Same for message on scheduled launch video on January 4.
  • The S5 is basically a "budget" option?
  • @endotoxic
    The Sony FX3 has a 12 MP sensor and was launched at 3900$, it's like comparing Apples vs Oranges.
  • No 4k 120fps 10 bit
    Fx3 2 years ago got it .
    Seems strange
  • Thanks for sharing the info @EspenB
    If the specs turn out to be true, I will congratulate Panasonic for finally listening to us and providing a proper PDAF system.
    If it doesn't have some major feature cuts, it may turn up as the best all-around camera @2000$ in 2023.
    If Sigma is providing paid service mount replacement to my E mount Sigma lenses I might change the A73 with this camera because I totally hate Sony ergonomics and menus.
  • @EspenB
    Thanks for topic and specs. Interesting.
  • Winter is coming.
  • So how fast will we get this Phase Hybrid AF in a Lumix G body. Hopefully a GH6M2 or a GH7 also in 2023.
  • The source is a post on a certain huge bulletin board, and the poster seems to be that person. The LUMIX S5 Mark II seems to be equipped with the long-awaited image plane phase difference AF, and it seems that we can expect a significant improvement in AF performance. Regarding LiDAR, which has been rumored so far, it is not mentioned in the spec sheet. Also, there is a description about the fan drive mode, so it seems to have a built-in air cooling fan.
    In addition, the new lens 14-28mm F4-5.6 MACRO is a wide-angle zoom lens that is compact and lightweight, can be zoomed up to 0.5x at the telephoto end, and can be equipped with a front filter.
    DC-S5M2
    effective pixel 24.2 megapixel full-size CMOS sensor, AR coating
    dust reduction is sensor shift type
    Video is 6K30p 4:2:0 10-bit, C4K 60p 4:2:2 10-bit, Full HD 120fps 4: 2:0 10-bit, full HD 60fps 4:2:2 10-bit
    3.68 million dots organic EL EVF, magnification 0.78x, eyepoint 21mm, refresh rate 120fps/60fps
    3-inch 1.84 million dots free angle monitor, touch panel, aspect ratio 3:2
    AF method phase detection AF/contrast AF, DFD, EV -6 - 18, AF assist light
    1728 zone multi-pattern metering, metering range EV0-18
    ISO range 100-51200 (50-204800 with extension)
    dual native ISO, Normal ISO 100 and 640, V-log 640 and 4000, HLG 400 and 2500
    5-axis image stabilization, 5 steps effect (6.5 steps effect with dual IS 2)
    Shutter 1/8000-60 seconds (mechanical), 1/ 2000-60 seconds (electronic front curtain), 1/8000-60 seconds (electronic), 1/250 second continuous shooting , 9 fps for AFS/MF, 7 fps for AFC
    (electronic Shutter) is AFS/AFC/MF and up to 30 frames per second.
    Buffer is 200 or more for RAW+JPEG, 200 or more for RAW, 300 or more for JPEG.
    USB Type-C port (USB3.2 Gen2)
    HDMI Type-A dual SD card slot
    Fan Auto/Auto 2/High speed/Normal/Slow/OFF
    Wi-Fi, Bluetooth v5.0 Battery
    life: 370 shots )
    657g (body only)
    DC-S5M2X
    24.2-megapixel full-size sensor
    6K30P video (full size) / 4K60P video (APS-C size)
    Supports Apple ProRes recording
    IP streaming function (Wi-Fi, USB, wired LAN)
    LUMIX S 14-28mm F4-5.6 MACRO
    lens construction: 14 elements in 10 groups (1 aspherical ED lens, 1 aspherical lens, 3 ED lenses, 1 UHR lens)
    Shortest shooting distance: 0.15m
    Maximum magnification: 0.5x (at 28mm) / 0.25x (at 14mm)
    Filter size: 77mm
    Size: φ84 x 89.8mm
    Weight: 345g
  • In the viewfinder "bump" there is some sort of active cooling solution implemented.
    1504 x 944 - 355K
