Top smartphone will use large IMX989 1" Sony sensor
The main component of the triple rear camera is a large 1-inch Sony IMX989 sensor with 50 million pixels. An optical image stabilization system has been implemented. In addition, two blocks with 48-megapixel Sony IMX586 sensors are involved: one with wide-angle optics, the second with a periscope design for optical zoom.
Dolby Vision HDR technology is supported, as well as 4K video recording at 30 and 60 frames per second. Leica Vivid, Leica Natural, Leica BW Natural and Leica BW High Contrast filters are available.
Smartphone has a Harman Kardon audio system, Wi-Fi 6E and Bluetooth 5.2 adapters, an infrared transceiver. The 4860mAh battery supports 67W wired and 50W wireless charging. The operating system is Android 12 with an add-on of MIUI 13.
The price is between $900 and $1,050.
Xiaomi 12S Ultra - photo camera with smartphone abilities
The main camera of the smartphone uses three 50-megapixel sensors. The main one is Sony IMX707 optical format 1 / 1.28 inches. Nothing is said about the rest, except for permission, but you can think that they will be smaller. The main module will use a lens with a focal length of 24 mm, the other two - lenses with a focal length of 50 and 14 mm.
If you look at the parameters of the main camera of Xiaomi 12 Pro, then it will almost completely correspond to the parameters of Xiaomi 12S Pro. What then is the key difference between the novelty? It is not yet clear. We can only say that Xiaomi 12S Pro will receive Leica optics, which will probably be slightly faster than Xiaomi 12 S Pro lenses.
In general, if you should not expect a miracle from the Xiaomi 12S Pro camera (and the Xiaomi 12 Pro camera, we recall, failed in DxOMark tests), then the performance of the model is really a little better: due to the SoC Snapdragon 8 Plus Gen 1, the smartphone goes beyond 1.1 million points in AnTuTu.
