Any experience with "Red Eye" wide angle adapters on Nokton 25mm ?
Raynox .66 or .7 i wonder if anyone tested these on DSLR (they are made more for camcorders) ...
Especially interested if tested on Voigtländer Nokton 25mm ?
Also any experience with "Red Eye" wide angle adapters ?
I found an adapter designed for DSLR that would even fit my Oly 14-35 F2.0 with its 77mm filter thread.
http://www.zunow.tv/Zunow-DWA-075.html
Has anybody used that adapter? And...its a bit pricey (about 700 EUR!).
This 0,7x is for dslr's. It has a 58mm thread and comes with a 52mm adaptor ring. It's a german company known for years making good quality optical accessories. Try it in store on my 25mm nokton next week. Company homepage just in german, sorry. http://www.hama.de/00044336/hama-weitwinkel-objektiv-dslr-htmc-07x?bySearch=dslr&searchMode=1
@AdR You learn something every day! Thanks!
There's a wide angle converter for the 14mm pancake and the X 14-42 lens coming out sometime from Panasonic and if it is properly matched optically then it should be a good choice.
Follow up on AdR's comments about the Super-35 format. He is correct about the use of slightly-wider lenses for a more cinematic appearance. One of my frustrations with consumer-grade camcorders was that their lenses were never quite wide enough. The lens specs he mentions are pretty much on the nose for 4/3 sensors.
I want to add something about the use of Super-35. That film spec was developed mainly to get a slightly larger original negative. Not only did this give filmmakers more leeway in reframing shots in post, but this enabled filmmakers to extract prints of high quality in nearly any image format they wanted. I remember reading a very detailed interview with James Cameron, where he talked about making widescreen prints of The Abyss for theaters, but also a full-frame 4:3 print for the home video market (back when this was an important concern). One trick he recommended was framing the shots from the top of the frame: he could crop from the bottom for widescreen, but if he wanted framing for 16:9 or 4:3, he'd crop less. The only thing he'd gain or lose was more of the actor's lower bodies.
@kronstadt, there is good news in store for you. Your cameras are better than you think.
The "crop factor" you refer to is a ratio used by still photographers to compare the sensor size of a digital camera to 35mm still camera film. However, still-camera film and cinema film are not the same. SLRs thread 35mm sideways, with the sprockets at the top and bottom. In cine, this is called 65mm or VistaVision, and the frame is much bigger than normal movie film.
Cine cameras thread 35mm vertically, with the sprockets on the sides. The standard frame is called "Academy Aperture" for the Motion Picture Academy, or more commonly called "4-perf" because the active image area is four sprocket holes (perforations/perfs) tall.
Since you're shooting video, you want to compare your GH1/2 to movie cameras, not to still cameras. The M4/3 sensor is very close to 35mm 4-perf. (Let's leave the "crop factor" for stills, and start calling this "Cine factor.") The Cine Factor of M4/3 is 1.19. That means that an 11mm lens on a GH2 has the same AOV as a 15mm on a Panavision 35mm movie camera.
Here's a chart to help:
So you can get plenty wide enough if you need to. A "normal" lens (45-degree AOV) on a cine camera is 30mm; on the GH2, it's 25mm. As you go wider, the difference is less.
Since you like a cinematic 2.39:1 aspect ratio, you can crop the top and bottom of the 16:9 picture off, just like Jim Cameron did on Terminator 2 and Steven Spielberg did on Warhorse. They use a special camera that crops the 35mm frame down to 3-perf, which is about 2:39:1. This is called "Super35."
You don't need super-wide lenses to get a cinematic image. It's a lot closer than you realize.
Hope that helps.
I got another wide 0.8x Olympus adatper to use with my Panasonic 14mm f/2.5:
