Rode Lavalier II
    Features
    • Low-profile design and compact mounting clip
    • Broadcast-grade sound quality with flat frequency response and omnidirectional polar pattern
    • 3.5mm TRS locking connector
    • Acessory kit includes a pop filter, mini furry windshield, mounting clip, colored ID rings and zip case
    • Permanently Polarized
    • JFET Impedance Converter
    • Omni-directional 6mm capsule
    • Signal-to-Noise Ratio: 67 dB
    • Equivalent Noise Level (A-Weighted): 27dBA Typical
    • Maximum SPL: 106 dB SPL RMS (Plug-In Power, 1% THD) / 120 dB SPL RMS (Plug-In Power, 10% THD)
    • Sensitivity: -38 dB re 1 Volt/Pascal (12.59 mV @ 94 dB SPL) +/- 3 dB @ 1kHz
    • Dynamic Range: 79 dB Typical
    • Power Requirements: 1.8v to 5v Plugin Power
    • 9g
    • 1200mm Cable
    • $99
  • 1 Reply sorted by
    554 x 463 - 28K
